Oil over full - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 03-15-2011, 12:51 PM Thread Starter
flagmanruss's Avatar
Oil over full
01.5 Truck is basically stock, except exhaust (as in signature). I discovered the oil level was over full. No sign of milkiness. No oil in coolant. WTF??
Where should I look?
Yes, really 10 years old & only 55,000 miles. (I never planned on getting sick but there it is.)
2001.5 Dodge Quadcab, 2500, 5.9, AD150, big line, 47RE auto, 4X4, 4.10, 265/75R16, 8800 GVW, TCW3 4"TBE, 36" FTE swirl resonator, straight through "muffler", IAT (mpg) fooler, XZT+. NRA LIFE MEMBER
flagmanruss is offline
post #2 of 22 (permalink) Old 03-15-2011, 01:01 PM
cumminapart77's Avatar
hmm...smell like diesel fuel at all? and was it hot or cold when you checked it
'01 HO, NV5600, Edge Juice w/Attitude,(100hp) injectors, Raptor 150, 5" MBRP, Mopar exhaust brake, 2.5" coil spacers, 295/70/17 nitto trail grapplers,17" Moto Metals, Southbend Dual Disc SBB3250
cumminapart77 is offline
The Following User Says Thank You to cumminapart77 For This Useful Post:
flagmanruss (03-15-2011)
post #3 of 22 (permalink) Old 03-15-2011, 01:01 PM
VP Moderator
dozer12216's Avatar
Was it inadvertlly overfilled. 11 quarts is normal. Dipstick tube is sometimes out of position.
does oil smell of fuel. Is engine missing or knocking or blowing white smoke???/
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
post #4 of 22 (permalink) Old 03-15-2011, 03:18 PM Thread Starter
The engine was cold when I checked it initially. I checked it a couple more times with same result.
Truck seems to run totally normally.
It might have been overfilled as I had it done & don't remember checking it after. (Breaking my own rules, to check oil after changes & check under truck. But I just don't recall.) It didn't smell like diesel to me but that is what I'm concerned about, I guess.
Stock lift pump (planning to install AD150 & big lines). VP44 has not been touched.
post #5 of 22 (permalink) Old 03-15-2011, 04:09 PM
Marble Crusher
MarbleCrusher's Avatar
well if it doesnt smell like diesel and the oil isnt milky and you havent checked the oil since it was changed last my guess would be that it was just over filled when the oil was changed.
-Jordan-
-02 Dodge 2500 cummins 4x4 6spd. Quadzilla XZT+, Volant CAI, road armor w/ lonestar guard front bumper line-x'd, Fass 95 , 3in lvl kit, bilstein shocks.
-68 F-100, grandad bought it new gave it to me when i was 16 been restoring bak to factory ever since.
MarbleCrusher is offline
post #6 of 22 (permalink) Old 03-15-2011, 05:13 PM
Diesel Filled Veins!
Sandman76's Avatar
Another way to check for diesel contamination in your oil is to drop a few drops on a piece of paper. If there's diesel in the oil, there will be a wet halo on the paper around the oil. No halo, you're good. The reason this works is because the thinner diesel will wick through the paper quicker than the heavier oil.
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
The Following 2 Users Say Thank You to Sandman76 For This Useful Post:
cumminapart77 (03-15-2011), flagmanruss (03-15-2011)
post #7 of 22 (permalink) Old 03-15-2011, 05:22 PM Thread Starter
Thanks sandman, I'll check it out.
post #8 of 22 (permalink) Old 03-15-2011, 05:29 PM
Sandman76's Avatar
Yer welcome! If you're not sure what you're looking for, put a drop of clean oil on the paper and put a drop of diesel next to it, then you'll see what you're looking for. Heck, you could even put a drop of diesel down with oil on top to see the halo effect.
post #9 of 22 (permalink) Old 03-15-2011, 07:33 PM
yea i'd say it got overfilled...
definitely do the paper test as sandman was suggesting it sounds easily enough done
by the way.. what exactly can happen if an engine is run slightly overfilled with oil for too long?
i know obviously way overfilled isn't an option but slightly over doesnt seem like itd be a huge problem (not that you want it that way) or am i wrong
post #10 of 22 (permalink) Old 03-15-2011, 11:08 PM
cumminsdriver92's Avatar
I accidentally overfilled mine a lil and was wondering the same thing? Should I just try and drain some out?
2001 Dodge Ram 2500 QCSB 4X4. Built in a farm shop
My play truck
1993 Dodge Ram W250 flatbed 4x4 5 speed. My work truck. Powered by Snap On Tools.
'MERICA
cumminsdriver92 is offline
post #11 of 22 (permalink) Old 03-15-2011, 11:51 PM
Sandman76's Avatar
A quart or so over isn't going to kill anything but way too much and you'll pop your main seals. Last time I got an oil change it took all 12 litres without a problem. Yes, 11 litres is what it's supposed to take. Saying that, I did go home and change out the Frantz filter which will eat almost a quart right there.
post #12 of 22 (permalink) Old 03-16-2011, 12:48 AM
90powerram's Avatar
If you are really concerned, you could send a sample in for analysis. That will tell you what, if anything, is wrong.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
