Air bleed on hydraulic clutch - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 02-25-2011, 09:25 PM Thread Starter
dieselroadrunner's Avatar
Does anybody know how to bleed the air out of the hydraulic clutch on an 01 1 ton 2wd 5 speed?
'92 W250 Auto, DennyT stage II, a few pump mods, Bosch 190's, 16cm, 4" TBE, BHAF, fresh paint, wheels/tires. Getting to be a bit pricey...
dieselroadrunner is offline
post #2 of 6 (permalink) Old 02-25-2011, 09:54 PM
Carbur8tr's Avatar
Did you just get a new master and slave? If so the only way I know how to bleed it is to hold the reservoir above everything else, fill it up and move the slave back and forth, not the clutch lever but the one that goes into the transmission. As you move it back and forth your notice air bubbles rise to the top of the reservoir. Keep doing this till you get all the air out, and youre good to go.
"To succeed in life, you need two things: ignorance and confidence."
Carbur8tr is offline
post #3 of 6 (permalink) Old 02-25-2011, 11:18 PM
CumminsCowboyNE's Avatar
I know somewhere on here is a really good write up on this try the google search on this site. I had the same question and I belive it was MoparMan that helped me out. but if you just replaced a part of it you need to take the whole system out and put the reseivor in a vice and have your slave lower than the vice then with the cap off fill up the reseivor with brake fluid and pump the system slowly from the slave cyl. side forcing the bubbles up this is the ONLY way to do it. trying to bleed it from the master cyl. side don't work. when it's all bled make sure your slave cyl. don't pop apart and put it back on the trans. then bolt up your master and try it. Hope this helps.
Get off my lawn.
CumminsCowboyNE is offline
post #4 of 6 (permalink) Old 02-25-2011, 11:49 PM Thread Starter
thank you both, we'll try that.
post #5 of 6 (permalink) Old 02-26-2011, 08:26 AM
jwalth02's Avatar
Here is that writeup by mopar1973man. Lots of good info on the site too.
Here: 2013 CCLB 6spd manual stock truck.
Gone: '02 24 Valve 6spd Manual
jwalth02 is offline
The Following User Says Thank You to jwalth02 For This Useful Post:
big blue turd (05-18-2011)
post #6 of 6 (permalink) Old 04-08-2011, 11:28 PM
interesting I called a dodge dealership and asked a friend of mine about bleeding the master and slave clyinder for the clutch and he said the way they bleed them is to unhook slave cylinder and push the rod all the in as far as it will go and hold it there and then pump the master in and out several times and that will force the air back up to the top,but he was very specific about making sure the slave rod stayed all the way in during the bleeding or it won't work,I tried removing the line at the slave and bleeding it that way,and made my clutch worse I have no pedal now,by the way I just converted mine from a auto to nv5600 with a new clutch and slave cylinder,also dodge dealers don't sell them pre-filled and bled,but I will try his way sunday and see if that works.
99 Ram 1ton 4x4 cummins,edgecomp tuner,silencer ring mia,140hp injectors,150 fass fuel ,steering stablizer,viper remote.converted from auto to a nv5600 6 speed.
simidrm is offline
