ABS Problem - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 02-16-2011, 01:21 PM Thread Starter
emhoff's Avatar
ABS Problem
Ok well heres the deal, my truck has been doing this since I bought it an today I bout ran into my garage door cuz of it. When you hit the brake pedal if you press it lightly its fine but if you hit the brake hard at any speed the ABS will kick in the the pedal starts to press hard an it makes the ABS sound an it wont stop, it will do this on icy roads OR dry pavement. I have looked over the hole system an I cant find any problems. No codes. Any idea's
2015 Ram 2500 CCSB Laramie LongHorn- HPP EFI Live, CSP5, 5" Exhaust, AutoMeter Gauges, Edge CTSII, Throttle Valve & CCV Delete.
emhoff is offline
post #2 of 6 (permalink) Old 02-16-2011, 01:33 PM
HOSS THE BOSS's Avatar
thats probably why my abs pump has been unplugged by the previous owner I haven't had any problem but if you plug it in, it runs constantly.
2001 dodge 2500 4x4 short box, 5 inch exhaust, edge juice with attitude cs stacked with a van aken, air dog 150, f1 mach 4s (150) hp, built auto transmission w/ the triple billet tq. duramax lockup actuator with the lock up switch hehe.2007 rims still adding.
HOSS THE BOSS is offline
post #3 of 6 (permalink) Old 02-16-2011, 02:01 PM Thread Starter
emhoff's Avatar
Yeah I thought about unplugging mine too, cuz its a major pain the a$$
emhoff is offline
post #4 of 6 (permalink) Old 02-17-2011, 11:32 AM Thread Starter
emhoff's Avatar
I'm still looking for an answer...
emhoff is offline
post #5 of 6 (permalink) Old 02-17-2011, 12:37 PM
dariddell's Avatar
try cleaning the speed sensor that is located on the top of the rear differential. if the sensor is dirty then it wont properly calculate wheel speed with the front thus causing the ABS to kick in... it worked for me!
2001 24-valve 4x4, Fass 150, Edge W/att hot, aurora 3000, 100hp sticks, BD converter, lock up switch, BD pressure loc, ats valve body, stacks, BD steering Stabilizer, american racing rims, afe intake
dariddell is offline
post #6 of 6 (permalink) Old 02-17-2011, 02:54 PM
whenpigsfly514's Avatar
I replaced the front left hub(to pass inspection) also the rear speed sensor and mine still does this. I then unplugged the front right hub and it stopped do it.
JOSH. 2001. QC. LB. 2500. 4X4. 47RE. TRANSGO. RAPTOR 100. S&B. 4'' TBE .QUADZILLA ADR. J-HOOK. BD STEERING STABILIZER. SOLD
2012 VW TDI JETTA
whenpigsfly514 is offline
