99 24v Crank but wont start - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 02-12-2011, 06:41 PM Thread Starter
Cummins 24v's Avatar
Ok guys looking for some incite to what this could be.
206,000 Miles
Getting fuel to fuel can
Getting fuel to injectors 1,3,4
50 degree`s outside at test.
Sometimes when im driving and coming to a stop it will stutter and try to rev up and then feels like it wants to die(mostly when its warmed up)
no real upgrades(intake/exhaust)is about it.
Could this be the VP?
Stil the truck dosnt wanna start. Any help to what this could possibly be would be very helpful. Thanks Brendon.
1999 RAM 2500 Dual 5" stacks, gauges Boost and fuel pressure one the way, intake, Driveway paintjob.
DODGE makes it CUMMINS shakes it
Cummins 24v is offline
post #2 of 7 (permalink) Old 02-12-2011, 09:07 PM
Follow the troubleshooting procedure at bluechip diesels site.
BernieL is offline
post #3 of 7 (permalink) Old 02-12-2011, 11:25 PM Thread Starter
It was a air leak, i got it.
post #4 of 7 (permalink) Old 02-13-2011, 01:07 AM
Clunk's Avatar
Good work, where was the leak?
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #5 of 7 (permalink) Old 02-13-2011, 02:34 AM
You all have a link to that troubleshooting guide? Mine started, but I could hear while standing outside the truck talking with a friend that it seemed to sound kinda softer than normal. The it just shut off. And now it seems to crank faster and easier than normal, and just plain won't start?
You all have any troubleshooting direction? That guide would be greatly appreciated.
2000, 2500, QC, 2WD, Auto, Stock Everything... ~75000 miles young.
Beans is offline
post #6 of 7 (permalink) Old 02-13-2011, 08:12 AM
VP Moderator
dozer12216's Avatar
Have fault codes read is a first step.
Try Blue Chip Diesel Performance Specialists for the diagnostic procedure.
Mopar1973Man has some intresting write up's also.
You might even do a search on this forum or look at sticky threads at top of this forum.
dozer12216 is offline
post #7 of 7 (permalink) Old 02-13-2011, 10:31 AM
Thanks for the insight and the link. Will there be codes to read even I'd there isn't a check engine light? Forgive me for my ignorance, as I've pined for a diesel for years, and this is the first one I actually owned. 2000 2500 5.9 no mods (that I know of), 77000 miles.
I'll have to go do the loan a tool program and grab the scan tool and get back to you. I'll go check theobvious stuff I've read about on these forums first, and post back on a new topic when I get that far.
Many thanks again for the input!
Beans is offline
