transmission problems - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 01-07-2011, 10:21 PM Thread Starter
I have a 1999 Dodge cummins. It doesnt want to shift into 3rd. I have to rev it up then let off the accelerator pedal then it will shift.Seems to be worse when cold.Truck has 133000 miles on it any ideas?
dslacy is offline
The Following User Says Thank You to dslacy For This Useful Post:
lanceunkovich (10-07-2011)
post #2 of 12 (permalink) Old 01-09-2011, 12:06 AM
logon444's Avatar
mine did the same i was told on here to put in a gov pressure selonid and it worked still shifts fine its been 2 months all good now when i pulled the pan mine had about 1/4 shot glass of metal so i know mine needs to be rebuilt so thats commin soon but i have heard of people putting 4,5,6 in their transmission before they rebuild so i would try that and see where it gets you
1999 2500 front and rear replacements winch in front, 4" turbo back, fass fuel, guadges (boost,egt,trans,fuel)
logon444 is offline
The Following User Says Thank You to logon444 For This Useful Post:
dslacy (01-10-2011)
post #3 of 12 (permalink) Old 01-09-2011, 01:42 AM
jakethesnake's Avatar
might pm a mod and have this thread moved to the 98.5-02 powertrain section for better exposure!
99 p-pumped 2.6 North East Diesel, Weston's Injectors, Schneider Machine HX60.
2009 qcsb deleted Schneider machine EFI live
Schneider Machine
jakethesnake is offline
post #4 of 12 (permalink) Old 01-09-2011, 02:53 PM
VP Moderator
dozer12216's Avatar
The first would be replace of speed sensor on left side, rear of tranny. It $20 or so and difficult to diagnois. cheap.
Does it shift into 4th and lockup normally?? If delays shifting into 4th also the governor pressure solenoid is a good possibility...
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
dslacy (01-10-2011)
post #5 of 12 (permalink) Old 01-10-2011, 10:43 PM Thread Starter
Do you know how much the part is and how difficult it is to change? Thank you for the info
dslacy is offline
post #6 of 12 (permalink) Old 01-10-2011, 10:49 PM Thread Starter
Thanks so much for the help.
dslacy is offline
post #7 of 12 (permalink) Old 01-10-2011, 10:55 PM
VP Moderator
dozer12216's Avatar
I recomend the OE part from dealership. Yes it costs more but have had better success with genuine parts...Go online with a MOPAR parts store and check price. some of our vendors handle them also.
post #8 of 12 (permalink) Old 01-13-2011, 11:47 PM
logon444's Avatar
it wasnt hard to replace just pull the pan (get filter and pan gasket before) if i remember right its under the filter but there is like a circle cage that has 4 screws take those out and bull the electrical connector then pull it out put the new one in (remember lube up the orings with trans fluid before re installing ) put it back to gether check the fluid drive it
logon444 is offline
post #9 of 12 (permalink) Old 01-17-2011, 12:12 PM
If it's the sensor that communicates with the ECM, you shouldn't have to pull the pan. It's about a 10 minute process.
2000 Dodge Ram 2500, 2WD, Quad Cab, 5th Wheel, KN Intake, 3.53 Diff, 47re xmission
TinSoldier
Glenn.Lewis is offline
post #10 of 12 (permalink) Old 01-17-2011, 12:19 PM
You can check the Diagnotic Code for proper troubleshooting. Use the ignition swith to cycle the OBDII trouble code. Turn on the Ignition to the Run (Not Start) position , then Off, Run, Off, Run. The Trouble Code will show up in the Odometer. It may be the Transmission Speed Sensor that communicates with the ECM (Computer Module.)
TinSoldier
post #11 of 12 (permalink) Old 01-18-2011, 08:14 AM
You dont have to pull the pan to do the VSS... But as dozer told me, jack up the rear end first or you could take a bath in tranny fluid.
You do have to pull the pan for the gov pressure sender. The gov press sender and the gov solenoid are bolted to the same block which bolts to the valve body.
You dont *have* to take off the filter, but I would. Unhook the connectors, remove 4(I think) 7/16" headed bolts and two(I think) torx bolts with a T25 bit, and the whole governer block comes off with the sensor and the solenoid.
The "cage" logon refers to is what actually holds the solenoid in the case. You will see a groove in the solenoid that the cage slides into.
The pressure sensor is held in place with a "m" washer. It will make sense when you see it.
If you are pumping alot of crap through there, here is a mod I read about on another site. You will have to register to see the photos. Its an easy mod to do while you are working with the components that wont hurt anything.
DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums - View Single Post - Help Me Out
The key on off on off on thing doesnt work on the 99...
Y'all say 'redneck' like its a bad thing
1999 3500 4wd auto ext cab- JUNKYARD FREE SPIN CONVERSION
NO MORE UNIT BEARINGS
1997 F350 crew 7.3 Powerstroke- modded
BoostedOne is offline
post #12 of 12 (permalink) Old 01-18-2011, 09:51 PM
Yep change the electronics,govenor pressure sensor and shift solenoid,might as well change fluid and filter and adjust bands while your right there.
99 Ram 1ton 4x4 cummins,edgecomp tuner,silencer ring mia,140hp injectors,150 fass fuel ,steering stablizer,viper remote.converted from auto to a nv5600 6 speed.
simidrm is offline
