OD operation in 47RE - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-17-2010, 02:15 AM Thread Starter
Ok, Im new to Dodge so I'm trying to get used to how things work. So please excuse the newb questions.
Anyhow, I just got a 99 3500. Since I got it from the auction I don't have any info on the truck other than the carfax and what I see. Its a 99 ext cab 4wd with 270K on the clock.
Im wondering just what makes the tranny go into OD? Or what conditions must be met? Reason is, because the truck runs great and strong. Steering seems tight, suspension feels good. 4wd works great.
Problem? In the limited time I had to mess with it, found the OD is not working. I offloaded the truck off the trailer, and drove it around the property a bit. THen went in the house for a while. THen wanted to take the boys out in it so I drove it around where we live a bit which is all dirt roads for about a mile and a half, so I couldnt get over about 20mph. Took it out to the hard road and everything seemed great. 1st to 2nd, shifted perfect. 2nd to 3rd, shifted perfect. But the faster I went, nothing happened, like it was a 3 speed.
Im doubting its the clutches or anything because its not like it slips or goes into neutral, its more like the tranny just doesn't know its supposed to go to the next gear.
I did some searching, and see posts talking about the speed sensor in the trans. I see some other stuff about solenoids. I also saw ONE post mention a temp sensor of some sort, but there was no response.
Would I be correct to assume that if it was a solenoid that the tranny would try to shift, but not make it(like go into neutral or something?)
One reason why I dont just jump on the speed sensor thing is because I think I read it will affect not only OD? In my case everything but OD seems to be fine(although I can't say if its locking up in 3rd either...hitting the od button on the shifter does nothing).
I think I read something about the temp sensor not allowing it until the temp was above a certain point?
It was cold that day, but I unfortunately also found out that the truck has a cracked radiator and didnt have much if any coolant in it... explains why the heat never did much.
Also unfortunately I only had that breif time to mess with it before having to leave town for funerals. Was just gonna wait till I got back but its really botherin me wondering and wanting to try to get a list of things to do when I get back.. And multiple trips to the parts store is not fun(iits about 20 miles away) and not really made of money this time of year.
BoostedOne is offline
post #2 of 7 (permalink) Old 12-17-2010, 03:17 AM
anotheraznguy's Avatar
what rear end? and what is the revs at say 60 mph?
2016 RAM Megacab 2500 4wd - Stock
99 QCLB SRW(Sold)
anotheraznguy is offline
post #3 of 7 (permalink) Old 12-17-2010, 03:56 AM
Thumbs up
Hey Boost, I'm no trans expert but let me offer this up...I have a 95 ranger that was doing the same thing. Everything was working fine except for OD couldn't get it to engage. Prior to that I had my radiator replaced and the new radiator apparently came with a new trans cooler..somekind of aftermarket deal. Unbeknownst to me my mechanic put this damn thing in and didn't tell me. I was about to junk it (220000 on it) when I decided to poke around under the hood and saw a bunch of hoses unattached that originally went to the factory trans cooler. Detached the new one and hooked everything back up and voila....truck ran like new again. I guess either the new one didn't have enough flow or heat transfer to cool the trans fluid but I thougt this anecdote might help. good luck. p.s. I've been asking questions on this forum about my 47re and seems no one has any answers unless you're talking about codes and .......
2002 slt laramie 4x4 ext. cab atlantic blue pearlcoat automatic 24v. 235hp.. Tried to grab life by the horns but I'm about to let go
mattyew is offline
post #4 of 7 (permalink) Old 12-17-2010, 04:34 AM
TURBOLVR's Avatar
iTrader Score: 8 reviews
Codes are often the best way to diagnose the issue. The 47RE IS an electronically controlled transmission and each sensor speed/temp/APPS/ect have an affect on how it operates. The trans also has failsafes that include a "limp" mode which disables OD.
'98.5 RAM 4x4 QC 12v, CRAZY CARL'S Whipple supercharger, Carl's SS SXE 64/GT55 twins, 13mm P7100,TUNNEL RAM intake plate, Hamilton head/valvetrain, , full 5" DUALS, BILLET AUTO
TURBOLVR is offline
The Following User Says Thank You to TURBOLVR For This Useful Post:
BoostedOne (12-17-2010)
post #5 of 7 (permalink) Old 12-17-2010, 11:20 AM
VP Moderator
dozer12216's Avatar
Since it seems to shift O'K in lower gears, I doubt the governor pressure solenoid is bad.
first would be replace the speed sensor on left rear of tranny. It inhibits OD if no signal received. Cheaper to replace than try and diagnois. Park truck downhill or get a atf bath on removing.
Also check for codes relaying to OD circuit. This would hint the wiring is fubarred or OD and or LU solenoid is suspect. If no codes than a mechancial problem with solenoids may be indicated. Drop pan and lookee see for condition.
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
post #6 of 7 (permalink) Old 12-17-2010, 12:08 PM
dhoagland's Avatar
OD off swith problem? (assuming it has one)
03 2500 SO QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, frame mount 3 Micron filter W/Water Separator, Big line kit "Wild Cat Version" 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet convertor, Super servo, 4 ring Accumulator.
dhoagland is offline
post #7 of 7 (permalink) Old 12-17-2010, 04:26 PM Thread Starter
I'd have to wait til I see the truck again to answer with any accuracy. But the revs seemed to be getting up there(2500-3K? Its hard for me to say, I am more used to looking at the tach in my Ford... But I wanna say the needle was pointing about 1:30-2:00), and I was only going about 50mph if I recall correctly. I do know that even working properly it will take a little adjustment for me since my other truck is an OBS F350 crew cab on 42" tires, and it still has 4.10 gears... So my ears are used to a sound of just lugging along even at 70-75... The dodge is still running the stock size Michelin street tires(and its gonna stay that way LOL...)... I don't have a clue what gear is in it..
Originally Posted by mattyew View Post
Hey Boost, I'm no trans expert but let me offer this up...I have a 95 ranger that was doing the same thing. Everything was working fine except for OD couldn't get it to engage. Prior to that I had my radiator replaced and the new radiator apparently came with a new trans cooler..somekind of aftermarket deal. <SNIP>
Yeah, I was wondering about that, since thats why I threw in the part about the radiator and temp sensor. I was going to expand on my thoughts but it was in the middle of the night when I posted and the baby wasnt feeling good so I was tryin to get done before he woke up the woman and gave me hell about being up on the computer.
But yeah, since there was little coolant circulating, maybe by the time I was on the hard road maybe the trans fluid was hot.. or if it uses coolant temp to decide, then maybe it thought the engine was still too cold. Either way, new radiator is being dropped off today and hopefully I will get it put in on Sunday after I get back.
The OD button on the shifter is problematic on these things too??
Ok, so I went to NAPA while up here in GA and bought the sensor. The guy asked me input sensor or output?? Do they have a sensor for the input shaft speed too? I ended up buying the "atp/output speed sensor".
Link to the sensor I got. Does that look like the right one?
What does APPS mean?
I'm going to throw this out there. Not sure if its related or not, but although the cruise control lights up on the cluster when cruise is powered on, it won't actually take over. But I would assume cruise uses the diff speed sensor, and the speedo works so its prolly a different problem.
So heres my current plan for when I get home.
1) Change oil, and hopefully not find coolant in it.
2) Replace radiator.
3) Test drive truck, see if OD magically fixed it self with a properly operating cooling system. If OD works, replace ATF and filter. Have my buddies scanner handy to see what the computer is requesting the tranny to do.
4) If problem persists, jack the back end up and replace the speed sensor.(thanks for the tip about having the back end higher.. didnt see that in other threads!). Will also adjust the bands while Im there.
5) Road test. If it works, replace ATF and filter.
6) If it still doesn't work then I gotta drop the pan I guess? At that time I will also do the filter and stuff. In the plan I have the filter at the last point just because I dont want to drain and replace it only to have to drain it all again if the radiator and speed sensor doesn't work.
Im guessing if the ECU is telling the tranny to go into OD and its not(and its also not slipping, just not shifting anywhere), chances are its a solenoid issue?
Man, I cant wait to drive this thing! Its going to be so nice to have a diesel that I don't have to stretch my legs to my stomach to get into!
