fuel drain valve leaks - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-01-2010, 03:27 PM Thread Starter
Had my old fuel drain start leaking. Bought new one from dealership and it leaks also. Have about 18psi at idle. Has anyone had this problem. Can we just block off the fuel drain with a plate? Any drawbacks for this as i have never used the fuel drain in over 250,000 miles. Could the fuel pressure be too much for the stock drain?
Thanks
Brad
2007.5 mega cab 2500 4x4 short bed. Auto/ 6.7. Full deletes. Straight pipe. Raceme program. Deep tranny pan. 35-12.50-18 Toyo at's. misimoto radator
greyheadeddodge is offline
post #2 of 7 (permalink) Old 12-01-2010, 04:42 PM
i ran 28psi with no leaks.. i'd make sure you didnt lose an O ring or something if it's leaking where it mates to the filter canister, otherwise you might find a good used one(i have one sitting around..), i haven't heard of anyone using a block off plate but i have heard of them leaking after 150k+ miles unused then finally being opened
2000 24v QCSB, BHAF, MBRP Straightpipe 4" Turboback, Quadzilla Adrenaline W/ V2 Pulse, 02 HO Motor, 02 NV5600, SO VP44, Con OFE Clutch, FASS 150, Etc.. Soon to come HT3B/HX35 Compounds, Dragon Fire VP44, 150ish Injectors, etc..
Just1More is offline
The Following User Says Thank You to Just1More For This Useful Post:
greyheadeddodge (12-02-2010)
post #3 of 7 (permalink) Old 12-01-2010, 05:04 PM
Denham's Avatar
Mine started leaking a couple months back, went to cummins, got a replacement. No leaks. Came with new o rings too.
"Fleetguard Drain Valve Kit," (P/N 395945300 S) for $14.66.
2011 Power Wagon
Traded - 2000 2WD Dodge 3500 Laramie QC Dually
Denham is offline
The Following User Says Thank You to Denham For This Useful Post:
post #4 of 7 (permalink) Old 12-01-2010, 06:27 PM
john.h's Avatar
What website did you go to? when I go to cummins.com they don't have anything like that and its all gift shop stuff.
oh btw I just found out my drian valve o-ring was leaking about 15 minutes ago
2002 4x4 cclb. 4" exhaust. nv5600. FASS 150. Isspro EV2 boost/fuel/pyro. Smarty.
2001 2WD cclb. Smarty, 4" straight pipe, Isspro EV boost/fuel/pyro, raptor 100, nv4500 (SOLD @ 317,xxx miles
john.h is offline
The Following User Says Thank You to john.h For This Useful Post:
post #5 of 7 (permalink) Old 12-01-2010, 06:29 PM
Denham's Avatar
I went to the cummins dealership in round rock, I'm sure they have one in waco.
2011 Power Wagon
Denham is offline
post #6 of 7 (permalink) Old 12-01-2010, 06:34 PM
john.h's Avatar
ahhh, for some reason I had it in my head that you ordered it online, sorry for the misconception. But thanks for the feedback!
john.h is offline
post #7 of 7 (permalink) Old 12-02-2010, 09:03 AM Thread Starter
Thanks all
Thank you everyone for your response. In looking at the new part i got from the dealership, i think it was used at one time. there is diesel oil in the bag with the new part and it was missing one of the o rings. i am taking it back to this lousy dealership and getting my money back and then buying another from somewhere else.
thanks again.
brad
