01 dodge ram 3500 47RE shifting problem 1st 2nd gear - Dodge Cummins Diesel Forum
post #1 of 37 (permalink) Old 11-10-2010, 11:20 AM Thread Starter
got a 47RE on 01 dodge ram. used to have no 1st gear. The truck would always start from second gear. Changed the pressure sensor and solenoid on the valve body and now have 1st gear.
Then new problem came up. sometimes, while in second, tranny would shift to 1st gear and the engine would be at a high RPM. Now it seems like in order to shift to second gear, i have to let go of throttle in order to shift into second gear if i am 2,000 rpm or higher. Then once in second, if i hit any hill or anything like that, it would shift back to 1st gear and i would be at 3,000 rpm.
Anybody know whats going on? Bad shift cable? Bad band adjustment? Thanks
KnightOwl is offline
post #2 of 37 (permalink) Old 11-10-2010, 11:29 AM
silvertungdemon's Avatar
sounds like your Throttle Valve cable is out of adjustment and the tranny thinks you are hard on the throttle so it down shifts or doesn't shift at all mine is a little frayed and once in a while it does the same thing when it gets stuck but definitely start there
1995 dodge ram 3500 single cab duelly flatbed standard and stock for now!!!
silvertungdemon is offline
The Following User Says Thank You to silvertungdemon For This Useful Post:
dozer12216 (11-10-2010)
post #3 of 37 (permalink) Old 11-10-2010, 11:33 AM Thread Starter
should i Oder a new one and try replacing it?
post #4 of 37 (permalink) Old 11-10-2010, 08:44 PM
it wouldnt hurt but it might need adjustment but i think when you get a new one it tells you how to adjust it i think it gets adjusted by the apps below your throttle cable
post #5 of 37 (permalink) Old 11-10-2010, 08:54 PM
VP Moderator
dozer12216's Avatar
Why not look at the cable and see if it is frayed or hanging. Need someone to open/close throttle while monitor movement at left side of tranny.
Or better yet, have it diagnoised by someone that is knowledgable of system.
dozer12216 is offline
post #6 of 37 (permalink) Old 11-11-2010, 01:04 AM Thread Starter
your saying remove the black cover by the engine, fire up the truck, hit the throttle couples of times..... then shift gears while the truck is on E brake and have a look at the cable assembly by the transmission? See if it moves when shifting from 1, 2 D and N?
post #7 of 37 (permalink) Old 11-11-2010, 02:39 AM
while under the truck look up at the transmission you should see two steel lines coming out of the tranny headed for the front of the truck look at the front most line and just below and in front of it you should see a lever that has a cable attached to it grab the lever and pull it twards the back of the truck if the cable moves the cable is fine there should be a spring attached to the lever if not or if its broken it can cause the same problem so you don't need to start the truck to check it operation
post #8 of 37 (permalink) Old 11-13-2010, 01:54 AM Thread Starter
yeah shift cable on the tranny moves back and forth nicely. I just dont understand why all the gears work great including the second gear if i am past 2k rpm ONLY but need to let go of the throttle when shifting from 1st to 2nd when 2k rpm or higher. Also if i hit the throttle when in 2nd and i am 2k rpm under, it shifts down to 1st gear and then causing the engine to scream very loud with little powder gain because i am at 20 miles an hour already and maxing out on 1st gear..
post #9 of 37 (permalink) Old 11-13-2010, 02:03 AM
sounds like low hydraulic pressure or a bad or sticking boost valve but it could be the throttle valve or almost anything inside the valve body
post #10 of 37 (permalink) Old 11-14-2010, 11:17 PM
I have heard that a leaking lip seal on the 1-2 clutch pack gives this symptom and it has been fairly common on valve bodies that boost line pressure for bombed engines. Can be checked with a pressure guage on ports.
Sootblower is offline
post #11 of 37 (permalink) Old 11-15-2010, 07:43 PM Thread Starter
is their a guide on how to check it>?
post #12 of 37 (permalink) Old 11-15-2010, 07:46 PM
ALLDATA Online - Automotive Diagnostic & Repair Information
