Cam positioning sensor location on 24 valve Cummins? - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 10-16-2007, 07:12 PM Thread Starter
On my 2000 Ram Cummins the RPM's gage started going crazy and the engine sometimes would surge and the check engine light came on. When I scanned it, it came up with the “Cam shaft Positioning Sensor”. My question is where is it located?
Thanks,
baffled is offline
post #2 of 15 (permalink) Old 10-16-2007, 07:14 PM
Motorsport Diesel's Avatar
Below the injection pump, on the rear of the timing cover.
Jesus Saves John 3:16 I once was wicked, but now I am saved
Real common rail goodies that you can't get just anywhere/2200 bar pressure relief valves that flow huge volume/2200 bar rail pressure sensors/ Exergy injector services/ CP3 pumps from daily drivers to single pumps over 1200 hp potential (for real)/ custom high pressure manifolds with multi ports for relief valves and sensors/Engine parts and more
[SIGPIC][/SIGPIC]
Motorsport Diesel is offline
post #3 of 15 (permalink) Old 10-16-2007, 08:37 PM
bbraden's Avatar
it's sort of right beside the starter bolted into the block if I remember right. I know that to change mine out it was a LOT easier to just pull the starter and then put it back in after the install.
'99 dodge 4x4 NV4500, Super X VP, FASS 150, Custom Quick Spool Super B w/ ATS manifold, RV's, Smarty programming. north of 400 hp... Bout to add water/meth injection
bbraden is offline
post #4 of 15 (permalink) Old 10-16-2007, 08:40 PM
that is the crank position sensor
[SIGPIC][/SIGPIC]
post #5 of 15 (permalink) Old 10-17-2007, 02:06 PM
Tech Specialist
Gary - K7GLD's Avatar
On an '02, it's right there, tucked up at the front of the engine between the VP-44 and the engine block:
Got REAL small hands?
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline
post #6 of 15 (permalink) Old 10-18-2007, 10:00 AM
WD and Gary are right, I just changed mine a few weeks ago. It can be done without the removal of anything but it is a bit of a PITA. BTW, that rpm's guage is called a tachometer :thumbsup Good luck.
okie
01, QC, 4x4, auto, Power puc, muff mia, SSI Steering Stabilizer, FASS 95, BHAF.
okiefired is offline
post #7 of 15 (permalink) Old 10-18-2007, 10:20 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
I was wondering if it could be done without pulling anything... It sure looks to be a PITA to do...
2002 Dodge 2500 (286k miles) - Quadzilla Adrenaline, +50HP Vulcan Performance Injectors, BHAF, 3" Flow Through Muffled Exhaust, AirDog 150 (10 years old)
Mopar1973Man is online now
post #8 of 15 (permalink) Old 10-18-2007, 02:35 PM
Yeah, the best way to get to it is with a very long extension and a hex head socket (cant remember the size off hand) to remove the small bolt that holds it in place. Have to come at it at a little bit of an upward angle if I remember correctly. BTW, Gary's picture needs to be rotated 90* clockwise to be oriented properly.
okie
post #9 of 15 (permalink) Old 10-21-2007, 05:14 PM
Free spirit
R-N-R's Avatar
Like this?
'02 2500, 2WD, 4.10, QC LB Cap, Bilstein, Gauges, DTT, IIS
R-N-R is offline
post #10 of 15 (permalink) Old 05-02-2008, 12:17 AM
REF>Lancer's Avatar
Originally Posted by R-N-R View Post
Like this?
Only,not to be a smart a$$ but aint that a cam position sensor there?
01.5 Ram 3500,dropped the mods,has bigger than stock injectors,4" MBRP exhaust.
610,000 miles so far.
Looking for a couple of drivers side doors for quadcab.
REF>Lancer is offline
post #11 of 15 (permalink) Old 05-04-2008, 04:36 PM
Ah......Ya......thats what this thread was about.
okie
post #12 of 15 (permalink) Old 05-04-2008, 05:16 PM
MCummings's Avatar
okie
X 2
Merrick
I have a few trucks. They are not stock.
MCummings is offline
