How to disconnect a trans cooler line fitting??? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 10-20-2010, 10:30 AM Thread Starter
I'm trying to replace one of my trans cooler lines and am unable to disconnect the fitting. I've tried using a fuel injector/transmission fitting tool and have had no luck. I'm using the 1/2" section of the tool. Any help would be appreciated.
99 qclwb Laramie, auto, 2wd, Quad Adrenaline (untapped) with IQuad, Isspro FP gauge, VP@195k, DTT Assassin lift pump, 94-96 fuel filter head SOLD
JHoward is offline
post #2 of 12 (permalink) Old 10-21-2010, 12:22 PM
bond150's Avatar
I need to know too. Mine is leaking and I either need to replace it or cut that fitting off and clamp the hose onto the hard line or get a new line/fitting.
1999 2500 QCSB 24v Auto 4x4, Daily Driven P-pump
bond150 is offline
post #3 of 12 (permalink) Old 10-21-2010, 01:39 PM Thread Starter
I've found another type if disconnect tool. Hope to have it done this afternoon. I'm going to try transmission line and a clamp first. The replacement line with crimp on fitting is $120 from the dealership & $70 pluse shipping from one of the forum members.
JHoward is offline
post #4 of 12 (permalink) Old 10-21-2010, 11:45 PM Thread Starter
Line Repacement
So in the end it was the aluminum line that runs from the rear of the trans to the front of the truck to just under the crankcase vent that had the leak. My rusty diagnostic skills and rush to complete the repair cost me $120 more than the correct diagnosis the first time would have. If I've learned from my mistake then it's worth it.
I started with a leak at the flex-line/hard-line fitting on I believe the return line of my 99 auto. What I thought was a leaky fitting ended up being a crease in the hard line (don't know how it got there) I found it after replacing the $110 flex line didn't fix the leak. I used a 1/2" AC/Fuel line disconnect tool from auto zone to remove the fitting. It was part of a set of four aluminum disconnects that where sold together. The first allin one that I purchesed didn't have a long enough sleeve to disengage the clips on the inside of the fitting.
The replacement of the $50 hard line took another trip to the dealership and 30 min of work by fluorescent lantern disconnecting clips and linkage, and snaking the hard line out towards the rear of the truck. Instalation was quick and painless with a large sigh of relief when upon start up I no longer had niagra falls under my truck. I'll try to post some pics of the fitting and tool.
JHoward is offline
post #5 of 12 (permalink) Old 10-22-2010, 09:04 PM
bond150's Avatar
Mine is leaking where the flex-line/hard-line come together. Do you think i could just cut the fitting off and push the hose onto the hard line and use a few stainless band clamps to keep it on there?
bond150 is offline
post #6 of 12 (permalink) Old 10-22-2010, 09:38 PM Thread Starter
Don't think the hose is long enough. That was my original plan, but I got tired of messing around with the wrong size hose. If you want to go that route the hose is 1/2" ID. Make sure you have a longer piece available before you cut it, if you don't have another ride available.
JHoward is offline
post #7 of 12 (permalink) Old 10-22-2010, 09:41 PM
bond150's Avatar
I have some extra 1/2 inch fuel line from my AirDog when I installed it. It's good quality hose and all I will need is a coupler and some good clamps. I know what tomorrows project is haha
bond150 is offline
post #8 of 12 (permalink) Old 10-22-2010, 09:59 PM
calltrex's Avatar
mine was leaking where it conects to the cooler.
so i bought new lines
still leaking
the cooler end was getting worn from vibration and stuff
so then i bought a new cooler
then it was all good.
thought about just a straight hose but didnt
2003 Dodge 4 door 4x4, Auto
Edge computer with attitude, AFE Cold Air Intake
4" Exhaust System. 33" Terra Grapplers Es
AirDog 150 Fuel System, Industrial Injection 90hp injectors, Banks High Ram, 48RE Special, ATS Manifold, Super Phatshaft Turbo, ARP Studs
calltrex is offline
post #9 of 12 (permalink) Old 10-22-2010, 10:08 PM Thread Starter
I had a really hard time wrapping my head around the price for the OEM parts. I have an even harder time wrapping my head around walking to/ missing work. So, in the end I forked over the dough and haven't looked back. Drove it 80 miles today, no leakes, no problems. In the end what ever works best for you is the best solution. It DID hurt my pride to pay $110 for 18" of 1/2"ID hose with a crimped on fitting with a MOPAR tag on it that I know I could have fixed with the right size hose and a clamp.
JHoward is offline
post #10 of 12 (permalink) Old 10-23-2010, 02:43 PM
bond150's Avatar
I got my fitting off and it looks like a peice of metal has worn a spot in the hard line and the fitting itself is leaking. And of course the stealerships parts departments are closed today and they have to order it anyway. So for now i have it rigged till i can get the real parts on it. Looks like i'll be forking out the money just so i know its good to go for a long time...
bond150 is offline
post #11 of 12 (permalink) Old 10-25-2010, 01:43 PM
bond150's Avatar
After looking around and seeing that people have replaced all of the lines including hard lines with heavy duty hydraulic line. I've decided to do that. I know where i can get 1/2" line. But does anybody know what kind of fitting i will need to connect the lines up to the tank looking thing on the pass side of the motor?
Is this what i need (the top fitting)?
http://www.napaonline.com/Search/Det...022033+5999999
bond150 is offline
post #12 of 12 (permalink) Old 10-27-2010, 01:28 PM
bond150's Avatar
Bump. Do yall think these fittings are the ones that come from the bottom of the water-to-oil cooler on the side of the motor?
bond150 is offline
