Transmission band adjustment/TV cable adjustment - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 09-21-2010, 06:21 PM Thread Starter
ramin2500's Avatar
On my 47RE How would I adjust the bands inside the transmission. I have been reading up on it and some people say just let it keep doing what its been doing since adjusting them could make it go faster...
Also would the TV cable have anything to do with it?
Any help or steps on how to would be great thanks.
Truck less
ramin2500 is offline
post #2 of 15 (permalink) Old 09-21-2010, 08:07 PM
dhoagland's Avatar
What is it doing
Band for second is adjusted externally
Reverse band, you will need to drop the pan
03 2500 SO QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, frame mount 3 Micron filter W/Water Separator, Big line kit "Wild Cat Version" 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet convertor, Super servo, 4 ring Accumulator.
dhoagland is offline
post #3 of 15 (permalink) Old 09-21-2010, 08:09 PM
Wyoming Eastern President
razocow's Avatar
Do tell on the band for second.....Please!
2000 quad cab short bed= Grandpa truck
S475 single, 7x23 dual feed injectors, fass 200, built auto, studded, two stage nitrous, Quad, Tial= SOLD
2007.5 QCSB Inferno Red= Dorthy
Fully Deleted, H&S Mini Max with OD, AFE intake, 5" straight pipe, H&S rail plug, FS2500 Bypass
-I rep for the AARP crowd-
razocow is offline
post #4 of 15 (permalink) Old 09-21-2010, 08:23 PM Thread Starter
ramin2500's Avatar
I'm confused now? What about the second band? I thought they were all under the pan?
Truck less
post #5 of 15 (permalink) Old 09-21-2010, 08:26 PM
dhoagland's Avatar
Band Adjustment (2001 47RE)
Band adj.pdf
This is from a 2001 Dodge Manual, 47RE Trans section
The Following 2 Users Say Thank You to dhoagland For This Useful Post:
02ram2500 (10-27-2014), Fern (11-28-2015)
post #6 of 15 (permalink) Old 09-21-2010, 09:29 PM
ned1999's Avatar
I just did my front band it made a bit of a difference. The band adjust set screw is a torx bit can't rember the size and a 18mm 3/8 socket with a extention to clear the trany lines. the set screw is located right behind the throtttle cable. unhook the spring so thaty is out of the way. then use the socket to mack the lock nut off about 5 turns. then turn the set screw in to 78 inlbs then back off 1 7/8 turns and hold the set screw and tighten the lock nut back up.
99 dodge ram 2500 4x4 3.55, auto, built trans, straight piped, s&b cold air and intake elbow, air dog 150, quadzilla Adrenaline with pulse, BD exhaust manifold, 35" tires
ned1999 is offline
post #7 of 15 (permalink) Old 09-22-2010, 02:25 PM Thread Starter
ramin2500's Avatar
Why did you adjust it? What problems were you having? How's it been since?
Truck less
post #8 of 15 (permalink) Old 09-24-2010, 04:33 PM
Bump!!!
I got the same question
2001 Dodge Ram 2500Long Bed Quad cab
Auto TransStock everything even the stock radio with a aftermarket dent in the bed(custom chevy imprint)
SomeGuyFromOlympia is offline
post #9 of 15 (permalink) Old 09-24-2010, 08:22 PM
gqrealtor's Avatar
Just an FYI, torque is 72 in lbs I beleive
gqrealtor is offline
post #10 of 15 (permalink) Old 09-27-2010, 08:42 PM
Anyone got anymore advice about this? I think I am slipping in first and second but am not sure since this is the first diesel I have owned
01 Dodge Ram 2500 4x4, QC, SB, Auto, Straight pipe 5" exhaust, 5" Superlift Lift, 35" Nitto Terra Grapplers
Mxrider52 is offline
The Following User Says Thank You to Mxrider52 For This Useful Post:
Boundaryranch (09-27-2012)
post #11 of 15 (permalink) Old 09-28-2010, 09:35 AM
dhoagland's Avatar
The band is for second gear only.
First gear = Rear clutch applied
Second = Rear clutch & front band applied
Third = Rear clutch & Front clutch (Front band released as front clutch was applied)
Maybe torque convertor?
post #12 of 15 (permalink) Old 09-28-2010, 10:55 AM
eastenn's Avatar
what about coming back down into 1st? as I come to a stop now, mine stays in second and won't drop down unless I manually pull it down. When the truck is cold it drops to first, but after it gets 180-190 it won't shift down. I adjusted the front band yesterday but that didn't help it. Does that sound like the rear band needs adjustment, or something with the TC once the fluid heats up?
'12 3500 ST CCLB DRW 6.7L g56 - 2.5" HBS level w/ Bilstein 5100s - running sims
eastenn is offline
The Following User Says Thank You to eastenn For This Useful Post:
Grapevine (10-11-2010)
