2001 dodge 24v transmission problem - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 08-27-2010, 06:13 AM Thread Starter
Cool 2001 dodge 24v transmission problem
I have a 2001 dodge 24v automatic with 140,000 miles on it. When pulling a load it will start to shake at low rpm's and in higher gears. Some what like it is not down shifting but if you let out of it and get back on the throtle it is fine. Also when i first start it and put it in gear it will sit there for just a little bit before engaging.
tmchaffie is offline
post #2 of 4 (permalink) Old 08-27-2010, 08:30 AM
husker's Avatar
I'm not sure what the problem is... I do know the guys are gonna want your signature filled out. That way the know what you have.
Edge Juice/Att HOT UNLOCK, Goerend Transmission, Triple Disk Converter, 4" Magnaflow Stainless Steel Exhaust, 200 h.p. injectors, Killer B turbo, S&B cold air box, AirDog 150, B&W Turnover Goosneck Hitch, High Idle Fooler, MPG Fooler. Stage 2 snow kit.
husker is offline
post #3 of 4 (permalink) Old 08-27-2010, 03:51 PM
VP Moderator
dozer12216's Avatar
Sounds like the torque converter is shuddering (slipping) at low throttle opening and relativelly heavy load. I would have thought the Goenends tranny would not be subject to this issue. What condition is the fluid and is it ATF+4.
dozer12216 is offline
post #4 of 4 (permalink) Old 08-30-2010, 07:36 AM Thread Starter
I have had it change every 75,000 miles so it is about due but it does not smell burnt or any real color change.
