Truck pulls hard to the left when braking - Dodge Cummins Diesel Forum
Old 07-17-2010, 01:13 PM   #1 (permalink)
My truck has started pulling hard left when I hit my brakes. It drives staright as a string but when I hit my brakes I have to steer to the right to keep from going in the other lane. Any ideas? Im thinking something with the brakes need adjusting or maybe new pads??? I dont know. Just need somewhere to start. The truck sat for a month or so and the driver side break sceeched real bad for about 500 miles, Its stopped screeching but now it pulls to the left. I figured the screechin was just rusty rotors
dbfd588 is offline   Reply With Quote
Old 07-17-2010, 05:06 PM   #2 (permalink)
dscotthef1's Avatar
sounds like a caliper is hanging
2000 2500 ext cab airaid cold air intake edge jwa and isspro egt fuel press. and boost gauges 5 in exhaust air dog 150 1/2 inch fuel line from tank to ip valair 550 sd clutch, 200 horse sticks super b special 1% tint debadged chopped seats
dscotthef1 is offline   Reply With Quote
Old 07-18-2010, 02:19 AM   #3 (permalink)
botlebruiser's Avatar
The screeching sounds like his pads are worn but the pulling to the left is a bad brake line. If it continued to pull AFTER you let off the pedal then I would agree on the caliper but this sounds like a line issue to me.
99 2500 QC LB~NV4500~Dana 80 LSD w/355s~84k (New VP)~Airdog100~Southbend ConOfe~BD 3rd Gen Trackbar~Carli Leveling Kit~TGC Control Arms~Silencer Ring MIA~MBRP 4"~BHAF Donaldson/Outerwears~Edge Juice w/Att~Amsoil~XD Hoss 35-12.50-20~Cummins Boys Will Survive
botlebruiser is offline   Reply With Quote
Old 07-18-2010, 02:28 AM   #4 (permalink)
ruidosododge's Avatar
iTrader Score: 5 reviews
what year truck do you have and do you have discs all the way around or disc in front and drums in rear
on my 01 that had the same problem you are describing it was a combination of worn everthing... drums and shoes were metal on metal and the pads and rotors were jacked up as well.... replaced it all and no more pull...
2012 TDI Jetta 6MT
Old Rams: 01,04,06,10
ruidosododge is offline   Reply With Quote
Old 07-18-2010, 09:03 AM   #5 (permalink)
dscotthef1's Avatar
that could definitly be the problem never thought about the brake line only reason i say caliper one of mine was hanging and didnt pull till i hit the brakes the only reason i found that it was hanging was the terrible brake smell
Old 07-18-2010, 11:50 AM   #6 (permalink)
xshellshock's Avatar
Pull the right side caliper off and see if you can compress the piston back into the housing. My bets are on that since he mentioned the truck sat for a month.
2002 2500 4WD QCLB - BHAF, 5" Straight Pipe, Supershafts 1 piece Aluminum Driveshaft, Performance Innovations Transmission, NP271D, Quadzilla Adrenaline with Pulse
Soon - Airdog 150 and some gauges
xshellshock is offline   Reply With Quote
Old 07-18-2010, 04:55 PM   #7 (permalink)
i agree, check the right side caliper its not braking as hard as the left one thats why youre going left. check the piston and make sure the caliper itself still slides on the pins, they could be seized up.
1999 3500 extended cab long bed 4x4. isspro fuel pressure, egt, and boost gauges. arp head studs. 150 injectors. kool-vue tow mirrors.
6-in-a-row is offline   Reply With Quote
Old 07-19-2010, 07:18 PM   #8 (permalink)
Hemijosh426's Avatar
my truck only does it after sitting in traffic. i think its my calipers after they get hot im thinking only one wants to work. such as a o ring hanging up from the aluminum housing getting warm? so i bought calipers we will see what happens. this post made me think about buying brake hoses also
01 24v dually 5spd 4x4. & 2004.5 24v dually 4x4 4 door ATS trans
93 d250 2wd 47rh lock up auto.406,000mi. CPP 7x.011
69 Dodge Dart Big Block 440 4 speed tunnel ram. :
Hemijosh426 is offline   Reply With Quote
Old 07-22-2010, 10:14 PM   #9 (permalink)
colten9212valve's Avatar
just throwin this out there could be a warped rotor as well??? if your replacing your calipers and pads id definetly take rotors to local parts store and have them turned.
2005 QCSB 4x4 6 SPEED-Willys Whistler Intake-Bully Dog Tripledog-5inch RSD Exhaust Straight Pipe to 6inch Tip-Isspro EV2 Guages
colten9212valve is offline   Reply With Quote
Old 09-10-2010, 11:43 PM   #10 (permalink)
My '97 did the exact same thing (although it's never driven straight as a string). Hard pull to the left with braking, gone as soon as you let up. Wound up being a plugged line to the right caliper. It was the rubber line, if I recall correctly. I'd put my money on that. Good luck!
'97 3500 4x4, ext cab, auto., straight piped to dual 5" stakcs, silencer ring MIA, AEM Brute Force air intake, fuel plate FF, boost elbow, GlowShift gauges, starwheel cranked
'98 2500 4x4, 360 V8, reg cab - all stock, plow truck
cwbyram is offline   Reply With Quote
