Cam sensor/timing - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 07-01-2010, 01:31 PM Thread Starter
The Big Green Tractor's Avatar
Cam sensor/timing
My buddy has a 99 dodge just like mine he recently put a new motor in. He says a cam sensor failed and his timing is turned back one notch and this creates a lope to the idle. My question is does all of this hurt the cam and other parts of the truck in anyway??? And do you lose power because the timing it pushed back a notch??? Thanks
99 Cummins Sport 24 valve 4x4 Edge juice w/attitude, rv275 injector tips, bhaf,Suncoast built tranny and torque converter, 5 inch straight to a 6 inch tip, sounds just like a semi. (53 block) 204k still runnin' strong!
The Big Green Tractor is offline
post #2 of 19 (permalink) Old 07-01-2010, 01:40 PM
Got P7100?
mathews8pt's Avatar
iTrader Score: 9 reviews
if the cam sensor is bad why not replace it?
what year was the new engine out of?
Hobie
2000 QCSB, 180 pump, 6x.013's, maxspool 2.5, s364/s480, tranmission built by me, AD150
11.23 @ 121mph
mathews8pt is offline
post #3 of 19 (permalink) Old 07-01-2010, 07:28 PM Thread Starter
im pretty sure its a 99 as well...
post #4 of 19 (permalink) Old 07-01-2010, 07:49 PM
runit02's Avatar
Yeah it doesnt sound good IMO. Having the valves open later than they should cant be good.
Official CF repair crew
[QUOTE=JearBear;19022602] I have always and will always love men, cats, and single cabs.
runit02 is offline
post #5 of 19 (permalink) Old 07-01-2010, 07:56 PM
ag cummins's Avatar
subscribed
00'4x4QCSB,Sport,NV4500,4.10s,SB Hydros,Luk SD,Killer.63/65/14,Tunnel Ram,CFM+,BHAF,5" Exhaust,ARP425s,Raptor150,DAP160hp sticks ,CompHot,ProComp gauges,Leveling kit,Farm built ladder bars,Borgeson shaft and gearbox,Trac bar kit,Steering brace,35s.
ag cummins is offline
post #6 of 19 (permalink) Old 07-02-2010, 11:06 AM
sledwrecker's Avatar
The valve timing doesn't change, that is mechanical. Only the fuel timing could be affected, but on another note, the cam sensor is NOT what controls fuel timing on a 98.5-00, that (I believe) is controlled by the crank sensor which has the tone ring. The cam sensor only references TDC on #1 for the computer which could have something to do with timing too but it is my understanding that all that happens with the crank sensor. 01-02 on the other hand has the tone ring on the cam gear (no crank sensor at all) therefore they are another story. I guess if he is getting a cam sensor code then that is where I would start.
00 SWB, Quad, Auto, 2wd, BHAF, FASS 95, Juice WAM, 4" Diamond Eye Strait,Smarty,3cyl/hi idle box.
98 RC 3500 4x4, 12 valve,DDP 75's,4k gsk,ARP studs,NV4500 with South bend 1 3/8" input shaft and OFE Con single disk,flatbed. 4" Diamond Eye Strait,BHAF.
sledwrecker is offline
post #7 of 19 (permalink) Old 07-02-2010, 12:34 PM Thread Starter
would the cam lobes wear out because the timing is back farther than it should be or not??? and i guess with the fuel timing that'd only make the truck a tad slower then huh???
post #8 of 19 (permalink) Old 07-02-2010, 01:24 PM
runit02's Avatar
I mis-read the post initially. Having the injection pump off a tooth does all sorts of interesting things... In the end the ecm just compensates for the discrepancy IIRC.
runit02 is offline
post #9 of 19 (permalink) Old 07-04-2010, 06:05 PM Thread Starter
so turning that timing back would change the fuel timing but would it cause the truck to light lope???
post #10 of 19 (permalink) Old 07-04-2010, 07:30 PM
I guess I mis read also, Kind of confusing.... So is that what you are saying is that he intentionally put the gear on 1 cog off? He would have had to pull the front cover to do that, you can't do it by just removing the pump. I took your statement that because the sensor failed his timing is off? Please clarify.
post #11 of 19 (permalink) Old 07-04-2010, 08:53 PM Thread Starter
ok heres the deal. he intentionally put the gear one off. then after that his cam sensor failed. really what i'm asking is if this would cause the truck to lope at an idle and if this is harmful to the truck in any way. sorry i didnt clarify that very well. basically he did it because it sounds "cool".
post #12 of 19 (permalink) Old 07-04-2010, 10:41 PM
runit02's Avatar
Yeah get that gear back where it belongs. That will do it.
runit02 is offline
