Rattling noise on 02 6-speed - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 06-30-2010, 09:29 PM Thread Starter
when my rpm's get to around 1850 i get a rattle almost sounds like a tambourine shaking and once it gets past 2000 rpm it goes away...anyone experience this problem...i'm thinkin maybe the clutch or a bearing somewhere ????
2002 2wd 6-speed 2500 ext,cab 8 ' box
bigmike is offline
post #2 of 14 (permalink) Old 06-30-2010, 10:18 PM
VP Moderator
dozer12216's Avatar
Will it do the same in different gears at the same rpm??
dozer12216 is offline
post #3 of 14 (permalink) Old 06-30-2010, 10:31 PM
My truck does the same thing. I think the noise comes from applying to much power and torque at to low of a RPM / in the wrong gear.
1999 2500 4X4 6 Speed SO,Garrett Powermax Stage 2,Banks PowerPac,Smarty,DDP 100HP Injectors,Fuel Pressure Gauge&Low Fuel Pressure Light,AFE Torque Tube Ice Box intake Amsoil filer,FASS w complete 1/2 fuel line,AmsoilByPass,Southbend 13" ConOFE
FLHTPI is offline
post #4 of 14 (permalink) Old 06-30-2010, 10:47 PM
xshellshock's Avatar
sounds to me like somethings loose and 1800-2000 rpms is its resonating frequency. Wheres it coming from?
2002 2500 4WD QCLB - BHAF, 5" Straight Pipe, Supershafts 1 piece Aluminum Driveshaft, Performance Innovations Transmission, NP271D, Quadzilla Adrenaline with Pulse
Soon - Airdog 150 and some gauges
xshellshock is offline
post #5 of 14 (permalink) Old 07-01-2010, 02:18 AM
markkerkof's Avatar
I had something similar and it turned out to be that shock that runs horizontal between the front tires on the steering parts. Cant think of the name of it. It was driving me nuts.
It was worn out and the parts were rattling like mad. Steering is much better and tracks better. Worth checking.
2001.5 Quad 4x4 5.9 24V Air Dog, Pyro,Tran,EGT, Boost Isspro. BHAF,4"TB,Super B,DynomiteDiesel 75s
markkerkof is offline
post #6 of 14 (permalink) Old 07-01-2010, 02:20 AM
Krazeeun's Avatar
check your shift knob... i have one of those geno's "Cummins Power" knobs and it would rattle around the same RPM range... i put it back together with a sh*t-ton of thread tape... quiet so far
2014 RAM 1500 w/6.4CR & SC47RE - 1550RWHP FUEL ONLY - 5.74@128MPH 660' - PS#6010
2015 RAM 3500 w/6.7CR & SC68RFEjr - 600HP FUEL ONLY - PULLS RACE TRAILER
1490 W HWY 98 MARY ESTHER, FL 32569 / 8559103823
"KNOWLEDGE IS POWER!"
Krazeeun is offline
post #7 of 14 (permalink) Old 07-01-2010, 07:28 AM Thread Starter
it does it in most gears ,definitely something under the hood,not the shift knob...sounds like passengers side under hood......if i put the clutch in and rev it i don''t hear the noise
bigmike is offline
post #8 of 14 (permalink) Old 07-01-2010, 07:21 PM
Banned
exhaust loose or rusted some where?
cumminsdog is offline
post #9 of 14 (permalink) Old 07-02-2010, 05:44 PM
Buyer of stuff..with OPM
Ram4Sam's Avatar
Assuming you don't have any obviously loose parts, you might be hearing be what is called "gear rollover" in the transmission. Google search "gear rollover" The nv5600 is a medium duty truck transmission, full of alot of big gears and shafts. The right combination of load,gear selection,rpm and engine harmonics will make some of the gears without a load on them rattle/vibrate on the shafts. Sometimes an oil change will help quiet the noise.
Sam
2016 3500 Laramie SRW(no fat chick) 4x4 CC LB ,Aisin,white w/brn-beige,,TOB/companion built 9/2015
Owned and gone, 1991 d250
... 2001.5 2500qc
...2014 3500 FCA buyback
Drivin' a Dodge Cummins since 1991.......
2008 Thor jazz 2870UK 5er....and 3 dogs.....
Search nazi's.......give it rest already....don't be an EDIC....
Ram4Sam is online now
post #10 of 14 (permalink) Old 07-02-2010, 05:51 PM
My noise doesn't concern me. My truck lives a good life with no abuse. My noise didn't start till I switched to Amsoil. Heavy duty transmissions make noise!!!
FLHTPI is offline
post #11 of 14 (permalink) Old 07-02-2010, 05:59 PM
Sam
What Sam said.
Transmission Noise
Gear Rattle is a repetitive metallic impact or rapping noise which occurs on a manual transmission powertrain
when the vehicle is lugging in gear. The rattle noise intensity generally increases with transmission operating
temperature and engine torque, and decreases with increasing vehicle speed. Since the gear ratios have been
designed to achieve maximum fuel economy, there may be instances when gear rattle is distinctly noticeable
under lugging conditions. This, however, is not detrimental to the engine or transmission provided that the gear
selected is appropriate for the vehicle speed.
NOTE:
Replacement of transmission components will not correct neutral rollover rattle.
Neutral Rollover Rattle has the same characteristics as gear rattle except that rollover occurs with the engine
idling, transmission in NEUTRAL, and the clutch engaged (clutch pedal released). The rollover noise intensity
increases with transmission operating temperature and engine torque load resulting from air conditioning and
generator. Neutral rollover noise is not detrimental to the engine or transmission. In vehicles where the engine
idle speed is below specification or rough, a harsh clattering noise like loose marbles in the transmission may
be heard.
Rollover Noise caused by engine torsional vibrations and Clutch Release Bearing Noise are sometimes
mistaken for Transmission Bearing Noise. Neutral rollover noise will disappear when the transmission is
engaged in gear. Due to a constant running clutch release bearing (used for the hydraulic clutch release
mechanism), noise caused by a worn or damaged clutch release bearing will be noticeable with the clutch
engaged or disengaged (clutch pedal released or depressed). Transmission service will not eliminate gear
rollover noise or clutch release bearing noise.
While verifying the condition, determine whether the noise is gear rollover noise, release bearing or some
other transmission related noise.
Gear rollover noise, inherent in manual transmissions, is caused by the constant mesh gears turning at engine
idle speed, while the clutch is engaged and the transmission is in NEUTRAL; and release bearing rub are
sometimes mistaken for mainshaft bearing noise.
Gear rollover noise will disappear when the clutch is disengaged or when the transmission is engaged in gear.
Release bearing rub will disengage when the clutch is engaged in the event that a bearing is damaged, the
noise is more pronounced while engaged in gear under load or coast than in neutral.
FLHTPI is offline
The Following User Says Thank You to FLHTPI For This Useful Post:
bigmike (07-10-2010)
post #12 of 14 (permalink) Old 07-02-2010, 11:03 PM
Erik_w's Avatar
I notice it when I'm doing maybe 15-20mph in 3rd, turning only. And I heard it after clutch job, resurfaced flywheel, tranny oil, and all u joints replaced
2002 2500 SLT Laramie SBQC 24v HO 4X4, NV5600, Posi, FASS 95, silencer delete, BHAF, gauges, 4:10's, 240,000
Erik_w is offline
