2001 5.9L Cummins Engine cuts out while cruising - Dodge Cummins Diesel Forum
 1Likes
post #1 of 15 (permalink) Old 06-26-2010, 12:26 AM Thread Starter
Please Help!
My 2001 5.9L Cummins cuts out when I'm cruising (40-60mph only) and I can't seem to get a good diagnosis. It feels like the transmission is slipping but I had the transmission checked and it's fine. The engine has little hiccups where the rpms slightly jump up rapidly yet the truck doesn't pull forward. This will happen for a fraction of a second many times in a row, then go back to normal for 20 minutes or so. If I accelerate at all the symptoms immediately go away.
Any ideas?
tbalanw is offline
post #2 of 15 (permalink) Old 06-26-2010, 02:54 AM
landworks0216's Avatar
check to see if you have any codes in it an report back
2002 Dodge Ram 2500 HO, SO VP44, 6 Speed, 4x4 with a 4 inch lift on 37/12.50R16.5 Military issue Humvee Tires
landworks0216 is offline
post #3 of 15 (permalink) Old 06-26-2010, 08:36 AM
Clunk's Avatar
Turn the keyswitch On-Off-On-Off-On then look at your odometer for P-codes.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
post #4 of 15 (permalink) Old 06-27-2010, 02:21 AM
HOSS THE BOSS's Avatar
could be fuel related if you are losing power may not be getting any fuel along with the cutting in and out also check the throttle senser if thats of course you don't have a cable. good luck by the way is your truck smoking of any color
HOSS THE BOSS is offline
post #5 of 15 (permalink) Old 06-27-2010, 11:13 AM
starstrungholsteins's Avatar
Sounds like APPS but unfortunetly could be fuel pump related. Obviously injection pump, but if it is gone I would question the strength of your lift pump.
98.5 2500 53 block w/ 470k km 4x4 AFE intake, WMI, HTT 62/65/13SS, BD 100HP stix, BD STLTH HPVP, 3 pc ex-man 4" TBE w/dual 5" tips ATS. FASS, Jw/A, BD Stg 3 tran...432 Hp 942 TQ 05/15/10 w/o W/M. Need to hit the rollers again! W/ some 1.5's? 2's?
starstrungholsteins is offline
post #6 of 15 (permalink) Old 06-28-2010, 12:38 AM
sean_mckay88's Avatar
Hi, I had a similar problem and narrowed it down to the MAP sensor. Truck would lose power and surge at highway speeds and through intermittant engine light. I pulled the sensor out, cleaned it with sensor cleaner and it has worked flawless since. If the MAP sensor isn't detecting any boost pressure it tells the computer to cut fuel supply. If your not sure, you will find the sensor right near you fuel filter on the side of the engine. I hope this helps!
2010 Ram 2500 TRX4- bone stock until warranty expires in AUG 2015!
sean_mckay88 is offline
post #7 of 15 (permalink) Old 07-03-2010, 02:20 AM
I am having similar problems. I have taken to the "go to" guys concerning fuel delivery in Dallas.
They first re-flashed my computer and cleaned the grounds twice which only seemed to help temporarily.
Then They removed a supplemental fuel pump. That didn't work.
Then they dropped my tank and replaced the in tank pump. That didn't work.
Then they thought it was my gas pedal position sensor so they replaced that.
That didn't work.
They for some reason could never duplicate the problem and after spending almost 2k in repairs they told me to bring it back when it was doing it all the time or threw a code.
They also said these symptoms were not typical of a injector pump problem.
I am as frustrated as hell and know you must be too. Hope you get it figured out.
onebobcat is offline
post #8 of 15 (permalink) Old 07-03-2010, 02:26 AM
What Kind of cleaner did you use?
post #9 of 15 (permalink) Old 07-03-2010, 02:28 AM
[QUOTE=sean_mckay88;3112636] I pulled the sensor out, cleaned it with sensor cleaner and it has worked flawless since.
What exactly did you use to clean your sensor??
The Following User Says Thank You to onebobcat For This Useful Post:
mopman10 (06-14-2015)
post #10 of 15 (permalink) Old 07-03-2010, 03:25 PM
flatlineracing's Avatar
brake cleen is what I used
flatlineracing is offline
post #11 of 15 (permalink) Old 07-03-2010, 03:41 PM
Originally Posted by tbalanw View Post
Please Help!
Any ideas?
Do you think this is the torque converter lock/unlock issue? If so, this has been hashed over many times and it should be pretty easy to fix. In fact, check out the stickied post at the top of the forum and there is a bunch of info. to read through.
2000 3/4 4x4 CCLB Auto. 203k, Dipricol FP gauge, 2 stroke lubin'er up, Raptor 100, "Swiss Cheese" air box suckin' wind, Power Puck.. .. Parts fixed - Vac. pump sealed, new rad., BD APPS noise filter, puke bottle gone.. So far, so good!
rockyraider is offline
post #12 of 15 (permalink) Old 07-06-2010, 04:33 PM
95cumminsturbo's Avatar
i heard u either go slow down for a little or speed up and it be fine or shut it off and re start it and it fine for awhile
96 f250 powerstroke 285k nuff fuel for 408hp.
89 dually 92 6.5 97 nv4500 murdered out
86 suburban 6.2 th700r4 , 94 cummins in sig traded
95cumminsturbo is offline
