Fan clutch removal - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 06-13-2010, 01:39 PM Thread Starter
Fan clutch removal
Hi. New retarded guy here. Having trouble removing fan clutch. Removed fan bolts.tried making fulcrum with pulley bolts but no luck with reverse threads. Any thoughts?
2001 ram 2500 4x4 5.9
tehachdude is offline
post #2 of 12 (permalink) Old 06-13-2010, 01:52 PM
VP Moderator
dozer12216's Avatar
A quick tap on wrench with hammer may break loose.
A small piece of wood to wedge belt and pulley will work.
Once you break it loose the game is over.
dozer12216 is offline
post #3 of 12 (permalink) Old 06-13-2010, 02:12 PM Thread Starter
Thanks. Ill give it a shot.
post #4 of 12 (permalink) Old 06-13-2010, 04:08 PM
99BigRed's Avatar
I had a hard time finding a wrench to fit the nut. I think it takes something like a 35mm. I bought a cheapy wrench 34mm (I think.... it was 1mm smaller) from the discount tool place (harbor freight) and ground it to fit. Then just bopped it with the mallet and it broke loose.
99 QCLB Red 4x4 53 block,nv5600,263k miles.Edge,ATS Manifold,Head Studs,Pacbrake,SouthBend Clutch,Raptor 150,Transferflow tank,BHAF, DAP injection pump,75HP Dap injectors
99BigRed is offline
post #5 of 12 (permalink) Old 06-14-2010, 02:18 PM
Kansas Chapter VP
Prowelder's Avatar
Hey,
What I've done in the past was built custom wrenches to fit the fan nut and the pulley bolts to hold it in place. A flat piece of metal works well, then just ad a handle in it!
Later,
Winslow
FOR SALE-Black 2005 Ram 2500 QCLB 4x4 Laramie with '06 front end, NV5600 with Toxic Diesel Shift Knob, Valair Ceramic SIngle disc, Isspro Gauges: Fuel Pressure, EGT, Boost. Bully Dog Outlook, Smarty TNT-R, AirDog 150, 5" exhaust, K&N Air Filter, CFM Intake Horn, HID Headlights, Rear Air Bags, Metal Moto 951 wheels w/ Fierce Attitude MTs... More to come!!
2001 Ram 2500 aka Black Magic, RIP
Prowelder is offline
post #6 of 12 (permalink) Old 06-14-2010, 07:33 PM
runit02's Avatar
Mines a 36mm. Leave the belt on a whack her. Its reverse thread, lefty loosey.
Official CF repair crew
[QUOTE=JearBear;19022602] I have always and will always love men, cats, and single cabs.
runit02 is offline
post #7 of 12 (permalink) Old 12-03-2011, 04:34 PM
mike honcho's Avatar
Ok, so i searched earlier, have printed info i got off of somedata while i was at school so i can remove front cover and what nots to retrieve my key for my injection pump.
I didnt have a fan tool of my own and its a 36mm. I barrowed/rented one from Kragen wich seemed to flex and rounded the nut off a couple times as well as damaged the pulley nuts. I decided to try and smack it with a air hammer to hopefully break it loose, instead it cut a hole thru the nut ( i used the air hammer as close to the actual fan/clutch as i could as to not hurt the threads.) Now im at a loss.
The only thought i really have at the moment since i have to buy a new clutch for the fan as it is, is to weld a piece of round or square stock to both the pulley and to the nut.
Any thoughts?
im trying to remain calm with the trouble im haveing as well as working outside the 1200sqft shop thats being occupied for the last 2 months by a broken duramax.
2001 2500, strait pipe 4" MBRP turbo back exhaust, HX35W, airdogII 165, Smarty S03, NV4500 swap, southbend clutch (375hp) 35" tires, 260K miles
mike honcho is offline
post #8 of 12 (permalink) Old 12-03-2011, 05:55 PM
sportster1208's Avatar
A long chisel or punch and a hammer and catch the edge- smack it!
1999 Ram 2500 standardcab, 2.8 puller
2008 Ram 3500 tow rig
B0TTSR brother of PA chapter
sportster1208 is offline
post #9 of 12 (permalink) Old 12-03-2011, 06:22 PM
Mopar1973Man.Com
Mopar1973Man's Avatar
Set of fan wrenches always make it easier...
Wrench turns to the right towards the driver side. (Loosen)
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For This Useful Post:
sportster1208 (12-03-2011)
post #10 of 12 (permalink) Old 12-03-2011, 08:35 PM
rhagfo's Avatar
I think they would rather beat the he__ out of it with a mallet, cold chisel and what ever else is at hand.
Having the right tools makes all the difference in the world, in ease of repair and amount of time and frustration.
01 2500 5.9 QCLB 4X4 5 Spd, Valair DD Organic, Power Puck, 298K miles ISSPRO Gauges FP, Pyro,& Boost. "A" Pillar, FASS DDRP-02, BIG Line Kit, 18 PSI, 3.55's, Kool Vue Tow mirrors, Bilstien 5100's, Pacbrake, Puke bottle deleted.
rhagfo is offline
post #11 of 12 (permalink) Old 12-03-2011, 09:09 PM
I didnt have the ability to make my own tool. brother took plasma and left me empty torch bottles. I also didnt have a place to go buy my own. I know this much. i will never rent a tool again.
I got to buy or make one later. I ended up getting it. Fawker was seized on. we used a hack saw and cut the bolt in half. later just because we jigged it up in the vise. took some more PB blaster and 5 min with air hammer to break free, when it did it ate the threads in the nut. only damage to idler threads were a small bur. i shoulda videod it.
I dont like half a--ing things or hack work either.
post #12 of 12 (permalink) Old 12-03-2011, 09:13 PM
Actually he said he didnt have the tool and was looking for a way to get it off after it was screwed up, you know do with what you got "now". I was a 5 star service tech for Chrysler for over 5 years and got well over ten thousand dollars worth of hand tools, most were bought for certain jobs to shorten the time because we were flat rate. I know all about right tool for the job!
