Replacing my 2002 dodge 2500 cummins fuel filter - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 05-06-2010, 02:42 PM Thread Starter
odie1830's Avatar
hey guy's, i'm just about to change my fuel filter and just looking for some help just so I don't screw anything up.
Any help would be great.
2002 dodge 2500 5.9L
2002 dodge ram 2500 5.9 ,
odie1830 is offline
post #2 of 10 (permalink) Old 05-07-2010, 07:51 PM
Click> 24 Valve Fuel Filter Change
Also moving to the 24 valve forum for better response.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
The Following User Says Thank You to illflem For This Useful Post:
Clunk (10-22-2012)
post #3 of 10 (permalink) Old 05-07-2010, 10:05 PM
Banned
Location: Oklahoma, and Houston 6 months out of the year.
It's real easy, I would be surprised if anyone could come up with a way to screw it up.
black01cumminstruck is offline
post #4 of 10 (permalink) Old 05-08-2010, 01:20 AM
99BigRed's Avatar
I put a small plastic coupler in the end of the drain hose on the water drain hose on the filter. Then plugged a small length of vinyl tubing into the coupling to extend it down to a container to catch the diesel. Drain the filter. Disconnect the water sensor from the bottom front of the fuel canister. Remover the nut on top of the canister while holding onto the filter canister. lift it out. Pull off the new hose but leave the coupling. Take out the filter. Clean everything. Replace all the o rings and coat with a little clean diesel fuel. Make sure the drain valve is closed. Fill the canister up about 2/3 with clean diesel. Carefully slide the filter almost all the way in...fill the canister with clean diesel almost to the top just it doesn't spill when you push the filter in all the way. Without SPILLING lower it back in and under the filter housing and tighten nut. Plug back in sensor. Wash your hands...lol. Start your truck. It should run without missing a beat.
99 QCLB Red 4x4 53 block,nv5600,263k miles.Edge,ATS Manifold,Head Studs,Pacbrake,SouthBend Clutch,Raptor 150,Transferflow tank,BHAF, DAP injection pump,75HP Dap injectors
99BigRed is offline
post #5 of 10 (permalink) Old 05-08-2010, 01:51 AM
Everything BigRed said, except I dont use the drain, they are troublesome, and prone to not sealing back up after using it, dont be surprised if it suddenly starts leaking or you cant get it to stop. easier just to leave it alone and syphen(use a turkey baster or rags) out the fuel outta the canister.
also take note if your lift pump has failed, this would be the time you will find out, If you dont have a fuel pressure gauge now you should be looking to instal one very soon, the stock LP's fail quickly and some trucks will run when they do fail, but over time it will take out the VP (1000-1500$) The fuel pressure gauge alerts you to a failed LP before you damage the VP44
If after you change the filter the truck starts and runs for 10-30seconds and then dies... likely your LP is dead, just giving you a heads up, as to what could go wrong
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
The Following User Says Thank You to nickg For This Useful Post:
Ricardo91 (03-04-2013)
post #6 of 10 (permalink) Old 05-08-2010, 06:59 AM
99BigRed's Avatar
I have only had it happen once since the truck was new but good point. I have a spare. I'm not turkey baster qualified.
99BigRed is offline
post #7 of 10 (permalink) Old 10-22-2012, 08:22 PM
pwrcummins's Avatar
i know this is awhile back but i have just one question. do u have to drain the fuel and why? i do but my brother in law says u do not have to and it is pointless.
06 ram 4x4, AFE CAI, MBRP 4" turbo back exhaust, 6" pro comp lift kit, 37" Toyo open country M/T, Auto meter phantom gauges (pyro, Boost, EGT), Skyjacker dual steering stabilizers, ranch hand bull nose front replacement bumper, 2 6" kc day-lighters,bully dog triple dog gt tuner, bd boost fooler, and more stuff to come
pwrcummins is offline
post #8 of 10 (permalink) Old 10-22-2012, 09:01 PM
Clunk's Avatar
If the Water in Fuel light isn't on, draining is optional imo.
Thanks for the link Bill, now I remember why I change mine that way.
Dave's site has been helpful to me since 1998.
'01.5 QC, SB, 6spd 4x4, Drag Comp, 4" exh. Jammer 100's, 62-65-.70A/R WG, adj.boost elbow Big Line, fuel press.pyro & boost gauges fuel cooler BHAF, Black Holley lift pump-12psi WOT Ceramic/Kevlar SD clutch, studs Take time to turn-so you don't burn
Clunk is offline
The Following User Says Thank You to Clunk For This Useful Post:
post #9 of 10 (permalink) Old 10-22-2012, 09:03 PM
pwrcummins's Avatar
iv always drained mine and thats how the auto shops had me do it that way too. now im confused lol
post #10 of 10 (permalink) Old 10-23-2012, 10:23 AM
You should drain it because there's little metal dust and other dirt in the bottom of the bowl from lift pump wear. It settles down there so it's best to clean that out.
I like the turkey baster route because I know how easily the drain lever starts leaking from wear. Only I'll use a hose with a bulb hand pump to pump it out.
I clean the bottom of the bowl by tapeing a small plastic hose to the shop vac and suck it out. Works great cause the hose is long enough to keep the dust away from the fuel.
mjgcamper is offline
