2000 4x4 with a 53 BLOCK!!! - Dodge Cummins Diesel Forum
post #1 of 37 (permalink) Old 07-24-2007, 02:27 AM Thread Starter
polaris_paul's Avatar
I bought this truck, with out even looking, how stuiped. I bought it at a sale, so in stuck with it. It is a 2000 sport, with 212000 KM (canada) and there is nothing wrong with it. What should i do. I looked and its a 53 so should i just sell it and move on, or do these things last? what KM's do they ussually go at, liek start to crack and leak?
thanks
2005 Cummins 2500, with a few extra goodies...
polaris_paul is offline
post #2 of 37 (permalink) Old 07-24-2007, 02:55 AM
JaredMTFD's Avatar
I had a 1999 with a 53 Block. I sold it at 106,000 Miles. Not sure how many KM's for you, haha. I never had any problems with it. I only sold it because I hated the automatic transmission. Never had a single engine problem.
[COLOR="DarkRed"]Current: 2004 CCLB 3500 Laramie Dually 6-speed, AFE Intake, Exhaust, Gauges
[/SIZE][/I][/SIZE]
JaredMTFD is offline
post #3 of 37 (permalink) Old 07-24-2007, 06:45 AM
Dad
Dad's Avatar
It is my understanding that the cracks generally open when you are towing under extreme conditions. I think many daily drivers have lived a full life and never shown signs of leaking.
- Mine: '09 GMC Sierra LTX ECSB 2WD - Deletes, 4" Exhaust, AEM CAI, DP LMM 2.6 Stg 1.5 Drag Turbo, BD Manifold, Diamond Eye Downpipe, All Season Diesel Performance EGR/Grid Heater delete, PPE Race Valve, Edge Insight, '08 Hummer Wheels, DSP5 - EFI Live tuning by Mark Broviak @ Danville Performance.
Dad is offline
post #4 of 37 (permalink) Old 07-24-2007, 07:51 AM
Boosted's Avatar
All hype on the 53 blocks.. I really wish someone could put together a list of actual seen cracked 53 blocks vs the actuall number made... i bet it would be so mynute that all of this might just die down...
Drive it and enjoy it...
2011 3500 CC DRW 4X4 Lone Star SLT - Auto - Race Me Programmer - DPF Delete - EGR Delete - S&B Cold Air Intake, Diamond Eye 5" straight pipe exhaust into a 7" tip
12 SRT8 Challenger 604RWHP
Boosted is offline
The Following 2 Users Say Thank You to Boosted For This Useful Post:
1BadOilBurnerN-Lv (02-15-2013), rpage (02-15-2013)
post #5 of 37 (permalink) Old 07-24-2007, 08:50 AM
flagmanruss's Avatar
I read up a lot on the "53" blocks... (thought my truck had one but it turned out to be a "55".) I could not get any hard numbers on the 53 but I think the percentage of failures is still low. Even if the failure rate was (hypothetically) twice that of "other" series blocks... the numbers would still be small... that's from a manufacturer's perspective... if we own one that fails, it's 100%!
But a crack is not necessarily the end of the block since they are repairable.
Within the 53 blocks, there are some with a casting mark which identifies a more crack prone casting. I'd certainly scope it out before dumping an otherwise good truck.
I agree that many of these trucks with the 53 blocks live out their lives without problems. Do a search...
Russ
2001.5 Dodge Quadcab, 2500, 5.9, AD150, big line, 47RE auto, 4X4, 4.10, 265/75R16, 8800 GVW, TCW3 4"TBE, 36" FTE swirl resonator, straight through "muffler", IAT (mpg) fooler, XZT+. NRA LIFE MEMBER
flagmanruss is offline
post #6 of 37 (permalink) Old 07-24-2007, 10:02 AM
Cummins 53 block
Good references on 53 blocks:
53 Block FAQ and Information
Cummins 5.9 Block
post #7 of 37 (permalink) Old 07-25-2007, 01:45 AM Thread Starter
CAn anyone tell me what serial numbers, etc are prown to cracking?
post #8 of 37 (permalink) Old 07-25-2007, 06:48 AM
Go for Broke
Graphic Man's Avatar
i am at 288,000 km's with a 53 block......with a few extra HP
no problems so far,.....i don't think i would worry about if i were you, from what i have seen and read only about 5-10 % of them crack
Scott
2015 Megacab Laramie 6.7 flame red
SOLD 08 Mega cab 6" lift with long arm kit, 2" leveling, flares, B/M, DPF delete, By-pass oil filter, cold air intake
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline
post #9 of 37 (permalink) Old 07-25-2007, 07:49 AM
From the reading that I've done, you can't tell by serial number but there is a rough area on the casting that they seem to have... visible from underneath. The best explantion I have is that the castings are not as think in that area (internally) and it is not the power out of the motor but rather uneven heating & cooling. Letting the CTD warm up normally & gradually is the recommendation. This is just good practice anyway.
Russ
The Following User Says Thank You to flagmanruss For This Useful Post:
CumminTheDaughter (06-20-2012)
post #10 of 37 (permalink) Old 07-25-2007, 08:36 AM
Smokinrebel's Avatar
I have actually seen a 53 block that was cracked, and when i say cracked i mean CRACKED...BAD. But i actually have a 98.5 with a 53 block. 140000 miles, with a little bit more fuel run to it and no problems so far...
98 24V Injectors, Quad Adrenalin, 4in Straight Pipe, K&N Intake, Silencer Ring Removed, Dead Pusher Pump, Georend Triple Disk Convertor and few other odds and ends in tranny All topped with a Loose Nut behind the wheel
Smokinrebel is offline
post #11 of 37 (permalink) Old 07-25-2007, 09:37 AM
cumminstexas's Avatar
Gus from farmboys 53 cracked I have video of it
-Duane Henrie
06 Cummins QCSB 4x4 Auto. Billet suncoast. PDI T4 Second Gen Mani. BD intercooler, intake mani and boots. II 85% over pump, II 120's. Hamilton 181/210, springs, and pushrods. HTT 64/71/13SS. Snow Stage 2. Lazarsmith Bars and gauge pods. T&C PRV. Smarty & MP8.
Thanks to Diesel Performance Outfitters of Texas
706/1401 on 2/1/11 12.2 @ 110
cumminstexas is offline
post #12 of 37 (permalink) Old 07-25-2007, 02:02 PM
LinemanTater's Avatar
I have a 53 as well and no cracks at 95K miles. But I don't pull the guts out of it either. It's pretty much just a road truck
2013, 2500 Megacab Laramie G56 (Manual 6spd) 4wd, PPEI EFI Live.
2007 5.9 mega Dually
1998 24v
LinemanTater is offline
