Fuel tank capacity - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 04-26-2010, 12:13 AM Thread Starter
markkerkof's Avatar
Fuel tank capacity
My 2001 24V Quadcab is supposedly equipped with a 35 gallon tank.
I've never put more than 31 gallons in it and the trip computer can say
ZERO miles until empty. I understand that they would build in a little room
for error, but 4 gallons?
markkerkof is offline
post #2 of 10 (permalink) Old 04-26-2010, 12:39 AM
Smokin-02's Avatar
My trip crap has never really worked worth a darn. The miles per gallon were about 4-5 off every tank. Its just an estimate. The only thing I use is the trip milage for remembering when to change the oil. If your speedo is off at all it effects the computers averages also.
02, 2500, QC LB, 6 Speed, Leveling Kit, 315/75R16E Fierce attitude M/T, Juice w/Attitude Unlocked, Fass 95, AFE, 4" Straight Pipe, Steering Box Stabalizer, Silencing Ring MIA!!
Smokin-02 is offline
post #3 of 10 (permalink) Old 04-26-2010, 12:44 AM Thread Starter
markkerkof's Avatar
Smokin 02, does your 4 in exhaust sound better? I hear some 5.9s that sound awesome
but I dont know what mods they have.
post #4 of 10 (permalink) Old 04-26-2010, 12:57 AM
Smokin-02's Avatar
It sounds awesome it is very loud with the windows down!!! I am thinking about doing the 5 inch from the down pipe back to get a little deeper tone. It will quiet it down a little. It is night a day different than stock or even when I had the 4 inch hi flow muffler on it. I did the AFE air intake first then did the 4" and then the rest of the mods. Sound changed a little bit when I added the Juice it cackles at full throttle and high boost.
post #5 of 10 (permalink) Old 04-26-2010, 08:02 AM
smok3rx's Avatar
When your truck hits Empty you still have 5 gallons of fuel left in the tank. I pulled my bed off yesterday to replace the basket in the tank and my fuel gauge was reading Empty but there was a good 3 inches of fuel in the bottom.
02 2500 Ext. Cab, Long bed, 4x4, 4" Turbo Back, BHAF, Airdog 100, New vp44, Quadzilla Adrenaline with Pulse v2
smok3rx is offline
post #6 of 10 (permalink) Old 04-26-2010, 08:08 AM
pepsi71ocean's Avatar
yea, you will have fuel left, as long as you don't have an intank pump, i think that is some reducilious number of gallons.
either way you are correct.
99 3500 Built DTT Auto, 600 lower TC, 3.55, 4x4, BHAF, 6" lift, ARP's, Danin Optix, Gauges, DAP 100hp sticks, FASS 95, 2LO kit, HIGH Idle, Silencer ring delete, 4" exhaust, SMARTY, 03 VW PASSAT 1.8T Big Thanks to (FTE Diesel),(DAP),(DTT)
They ROCK!
pepsi71ocean is offline
post #7 of 10 (permalink) Old 04-26-2010, 08:50 AM
rwhite1's Avatar
It is ridiculous - I've run 50 miles w/ the low fuel light on and still only put in 29.5 gallons. Most I've ever put in.
'99 2500 nv4500 QC LB 4WD - 368hp/728tq.
Back to stock now - PSC PS pump, Borgeson box, steering brace, Exhaust brake, Southbend clutch
rwhite1 is offline
post #8 of 10 (permalink) Old 04-26-2010, 12:34 PM
Dave2001's Avatar
My low fuel light comes on when I have 8 gallons left. My question is: What is the least amount of fuel you can have in the tank with the stock pickup and still get fuel to the engine?
2001.5 Ram 2500 Quad Cab, HO, 6 speed, 4.10's, RV275 injectors, Quadzilla XZT+, AFE 4" Exhaust, ISSPRO Gauges (EGT, FP, Boost), K&N Air Filter, Raptor 100 Fuel Pump, 1/2" line with AN fittings to the fuel filter, 6AN fittings fuel filter to pump.
Dave2001 is offline
post #9 of 10 (permalink) Old 04-26-2010, 01:34 PM
rollinblacksmoke's Avatar
well... I have put in 33 gallons cause I was cutting it kinda close about 2-3 gallons left you will notice the loss of power I would not recommend it.
1998 RAM 3500 4x4 12V
rollinblacksmoke is offline
post #10 of 10 (permalink) Old 04-26-2010, 04:57 PM
kevstar1212's Avatar
Just a side note i got 4 inch dp and 5 inch all the way back to 6 inch tip and i get compliments on my truck all the time. People always tell me that my truck has the classic deep throaty cummins sound that everyone is looking for. Doesn't drone too bad either. I heard the 5" helps with it.
2001 2500 ext cab short bed 4X4, 2" level kit, S&B intake, 4" Down pipe ,5" exhaust, Fass 150, Silencer Ring MIA, Gauges (Boost,EGT,Trans Temp,Fuel Pres), Edge Juice, Recon Billet Triple Disc TC, Transgo Shift Kit, 125 HP Injectors
kevstar1212 is offline
