KDP tab question - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 03-24-2010, 11:24 AM Thread Starter
KDP tab question
Looking to tab the KDP in my '99. Is the case the same in a '97 as a '99?
Mark
1999 Ram CTD 2500 QC SB Laramie SLT 4X4 / Dipricol Gauges / RV275 Injectors / Edge Comp / Raptor 150
Vulcan Draw Straw I / Goerend Triple Disc / Hog Performance 4" Exhaust
Marky Mark is offline
post #2 of 5 (permalink) Old 03-24-2010, 11:48 AM
I put a tab in my 98 24v. Cummins claim the fixed it in the 24v but there are cases of them coming out. They are not as common as the 12v but $60 for the kit and a little time is cheap insurance versus what could happen if you don't tab it and it comes out.
1998 QC LB 4x4 24v auto
a93sn8ke is offline
post #3 of 5 (permalink) Old 03-24-2010, 06:10 PM
yoshi470's Avatar
Im curious as what comes in the KDP kit? All you need is a little tab that could easily made by yourself out of a little piece of scrap metal? I just tabbed mine on my 24v and it was starting to come out and my truck is an 01
2012 Dodge Ram 2500 Laramie Longhorn
H&S XRT Pro, MBRP 4" TB Exhaust, More to come!
yoshi470 is offline
post #4 of 5 (permalink) Old 03-24-2010, 06:25 PM
mbroadwick's Avatar
pardon my ignorance, but what exactly is this "KDP tab"? and what does it do?
'02 4x4 nv5600, 315's, k&n, 7" cat stack, autometers, airdog150, "LO" vp44, ddp 200's, edge drag comp, valair 3850lb DD, 110lb dual valve springs, studs & o-rings, spool-aid, 66/74/14. 102k miles. My neighbors hate me
mbroadwick is offline
post #5 of 5 (permalink) Old 03-24-2010, 09:02 PM
Carter2409's Avatar
it stops this from happening
kdp is a bold that falls out, gets stuck between the gears in there and cracks the timing gear housing,
not the cover the housing, id tab it before it falls out and then you are in some deep sh!t
Far from stock
Gathering parts for a p pump swap
Carter2409 is offline
The Following User Says Thank You to Carter2409 For This Useful Post:
mbroadwick (03-26-2010)
