- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
Help with Trans Please!
lately my transmission has been acting funny. sometimes when coming to a stop it wont down shift into first gear. and when i go to take off it acts like its still in 3rd or 2nd, but if i pop it down in neutral and back into drive. it will jump just like usual and take off normally. need help please. what could this be?
Thanks, Brad
99 24v 4x4, BHAF, FBD 4" Down Pipe to 5" Straight Pipe, Silencer Ring GONE, Hypertech 3 Stage, Lock-Up Switch, Eagle Alloys and some wide 33's
#2 (permalink) |
subscribed...........................
2000,4x4, quad, 315procompAT's, XZT+ to big hoss level 5,banks high ram,banks wastegate,100hp injectors,4"tbe,TAG,ranch hand bull nose,leveling kit, auto with hughes perf. TC and VB,pillar gauges- trans,pyro,boost,fuel press, BHAF, 2 LP's @28psi
#3 (permalink) |
![]() Join Date: Jul 2008
Take to a local trans shop and have him do a quick check.
99 QCLB RED 3500 SLT 4x4, #53 block (179,000- no crack), original IP, ARP studs, NV5600, 3.54 LS 13" SB Clutch, Pacbrake, ATS manifold, 4" exhaust, Raptor 150, 10 psi LFP light, 4x4 Cutout Switch, Edge Comp, K&N filter, Autometer Pyro/Boost/FP, Transflow 54g fuel tank, Alcoa wheels and Kenwood tunes. I never try to match wits with an unarmed person.
#4 (permalink) |
bump, any ideas?
#5 (permalink) |
bump again. i need help, this is my only vehicle and im a broke college student! ha
#6 (permalink) |
So I have the same problem and think I stumbled on the solution last night. There's another thread on here entitled "DTT trans - No Low Gear" same problem we're having and the shop told him to replace the governor solenoid and pressure sensor... it worked. I also found another post in a different forum
Governor Pressure Solenoid / Sensor - TDR Roundtable same problem and the same fixed worked. I plan on spending the $160 to buy the sensor and solenoid and trying it out. Almost 100% its your problem too. ![]() Hope it helps.... |
#7 (permalink) |
awesome! i was hoping it wouldnt be something to expensive. is it something you did yourself?
#9 (permalink) |
good deal. let me know how it goes! thanks alot
#11 (permalink) |
Great to hear man. Was it fairly simple? any difficulties?
#12 (permalink) |
Very simple. Just drop the pan and you'll see both the solenoid and the sensor held on by a bracket. Remove the 3 hex hds and the 2 torx bit screws. The bracket pulls down and the solenoid comes with it, then you can remove the sensor.
