Why do I keep tearing up belts???? - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 02-24-2010, 09:04 PM Thread Starter
right_on's Avatar
I know i'm in the wrong section but i need help. This will be the Third belt i have put on. I replaced the tensioner pulley last week but the belt i left on there had a couple of lips missing and tore another lip off tonight. The belt are coming apart lip by lip and the lip that comes off is always wrapped around the crank pulley between the bolck and the pulley. Could this be my damper going out?
2000 2500 Sport 4x4, AFE CIA, Quadzilla XZT+, Exhaust, Torque Converter, leveled, 20INCH XD BADLANDS
right_on is offline
post #2 of 14 (permalink) Old 02-24-2010, 09:35 PM
Cummins CrAzY
DevilDogDiesel's Avatar
Almost all the time it is the tensioner. Did you just replace the pulley or the entire tensioner? As for your damper as long as the rubber isn't hard cracked and fallin out it should be good to go.
2000 2500 ext. cab short bed, AFE cold air intake, single 6 inch stack, SPS 62 turbo, FASS 95, Scheid Lightning II's, .093 connector tubes, Maxspool valve springs, A1 head studs, Fire ringed head, Adrenaline, HP intercooler boots, 6 speed with a Haisley Street puller clutch, custom trac. bars, draw straw
DevilDogDiesel is offline
post #3 of 14 (permalink) Old 02-24-2010, 09:46 PM Thread Starter
right_on's Avatar
I replaced the entire tensioner
right_on is offline
post #4 of 14 (permalink) Old 02-24-2010, 11:19 PM
I've seen on an 03 that we changed the tensioner, and he kept eating dayco belts, whent with a gates gatorback and has not had an issue since. have also heard that some times the tensioner my require a small shim under it to keep the belt from being "run" off, although I have no experience with this .
I found the dayco tensioner(square looking plastic pulley) was pretty crappy compared to the gates one (steel wheel)
2003, QC/SB. Edge Juice,Hot, AirDog150/BMS50 nozzles S&B CAI, BD Flex plate/tripple loc T/C. georend VB/ Trans rebuilt by Me. Bilstien5100. carli coils, Air Bags. RETIRED Military Mechanic (20yrs)
nickg is offline
post #5 of 14 (permalink) Old 02-25-2010, 12:33 AM
I replacement my tensioner also with the gates tensioner and mine is doing the same thing. It ate one lip and I pulled it out from around the crank pulley but I did not readjust the belt just left it how it was. I have not had any problems after
2000/ 24V / 5 speed / custom replacement bumper / Engine just rebuilt stock
/ pillar gauges/ dumped exhaust/ quad xzt+/ raptor 100/ Vulcan big line kit
Double O Dodge is offline
post #6 of 14 (permalink) Old 02-25-2010, 12:38 AM
Rescue Tower
Shainer's Avatar
A pulley is out of alignment somewhere. Make sure all pulleys are on tight and running on the same plane.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #7 of 14 (permalink) Old 02-25-2010, 08:06 AM
ROLLIN SMOKE DIESEL
Broke Down's Avatar
iTrader Score: 13 reviews
check the idler pulley also....... easily over looked also. this is going to sound dumb but is it the right belt? i had a belt in the wrong cover once
Duke- 2004.5 2WD SSR Tuned
Feel free to email me for quotes:
Monday-Friday 8am-5pm CST, online ordering 24/7
Broke Down is offline
post #8 of 14 (permalink) Old 02-25-2010, 07:16 PM Thread Starter
right_on's Avatar
It fits like the right belt. Looked at the crank pulley while running and it seems to wobble a bit, that should be my problem.
right_on is offline
post #9 of 14 (permalink) Old 02-25-2010, 08:01 PM
VP Moderator
dozer12216's Avatar
Slight wobble on crank should not be a problem. Look at all pulleys while running and see if belt favors the outside or runns in middle. Check for alignment. Sometimes the alternator is installed out of alignment, idler pulley bad, tensioner assemblly allowing belt to run on edge, AC pulley/bearing bad or misinstalled. Water pump bearing loose but not leaking, anything not allowing belts to center themselves on pulleys.
dozer12216 is offline
The Following User Says Thank You to dozer12216 For This Useful Post:
right_on (02-26-2010)
post #10 of 14 (permalink) Old 01-30-2011, 08:11 PM
Jakey's'01H.O.'s Avatar
gatorback part number for 2001 with ac?
'01 ETH/MONSTER VP. 835/1698 and a valve seat visited cyl 4...build in progress.
Jakey's'01H.O. is offline
post #11 of 14 (permalink) Old 01-30-2011, 10:19 PM
VP Moderator
dozer12216's Avatar
And check alternator mount for wallowed out mounting hole..
post #12 of 14 (permalink) Old 01-30-2011, 10:47 PM
jshmohr's Avatar
Hey I manage a NAPA and the gates # for the belt is #25081264 or put a HD on the end for the heavy duty fleet runner belt. Also like they said make sure everything is aligned and non of the bearings are failling. P.S. that # was if you have a/c.
99 24v Quad cab long box 4x4 75hp injector nozzles, Edge Juice w/att and hot unlock, fass 150,BHAF, High Idle fooler, billet converter, trans-go shift kit, 4:10 gears
jshmohr is offline
