front oil sump change - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 02-06-2010, 11:28 AM Thread Starter
hi i'm putting in a 1996 6bt in a 1986 chevy and i need to change the oil pan around fron a front sump set up to a rear sump set up. i need to know if anyone has done this and how it is done.
nathan1534 is offline
post #2 of 3 (permalink) Old 02-06-2010, 12:30 PM
VP Moderator
dozer12216's Avatar
If you look around, there is probablly a application in other vehicles or commercial systems.
dozer12216 is offline
post #3 of 3 (permalink) Old 02-06-2010, 01:52 PM
wcuhillbilly's Avatar
I mentioned this to the Cummins Techs once,,,, they told me that the oil pan is reversable, and that the oil sump tube was (If I recall correctly) the only differance.... the sump tube comes out of the front of the engine, in the crank case and runs via tube and pick up to the rear for our application. in the industrial application it comes out in the same location, just a differant tube,(shorter) and falls straight down for the front sump..... go talk to Cummins for the "B" series tech manuals.... the one I got for the Dodge application was a 1991 version for $20.00,,, no real updated manual has been put out cept for a small update for the 24v. which is what I was useing for my Repower application. the engine in general is the same.
2001 24v P-Pump Cummins, NV4500/NP205 transplant, 85 K30 CrewCab Dually D60, 14 Bolt 3:73....ATS Pulseflow, Banks Intake. BD I/C Boots, Jake Brake,(slightly modified) Studs, DDP 75hp inj, PDR HX35 HybridBuilt, NOT BOUGHT !!!! M816 Wrecker NHC 855 small cam Cummins
wcuhillbilly is offline
The Following User Says Thank You to wcuhillbilly For This Useful Post:
nathan1534 (02-06-2010)
