Block Heater Location? - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 01-04-2010, 08:33 PM Thread Starter
Last summer I was blessed with a good deal on a low mileage 2000 Ram 2500. However it did not come with a owners manual. I need to know the location to connect a block heater cord and type of cord is needed? Very cold weather is heading towards us and I'd like to be ready.
Thank You
Outcast is offline
post #2 of 11 (permalink) Old 01-04-2010, 08:42 PM
Cummin try me's Avatar
here is the link for the cord FLEETGUARD ENGINE BLOCK HEATER CABLE - ('94-'09 DODGE)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage The element itself is on the passenger side of the block back behind where the oil filter is located.
1995 2500 4x4 47rh
VALAIR ClutchPureDieselPowerMumau DieselHamilton Cams
Cummin try me is offline
The Following User Says Thank You to Cummin try me For This Useful Post:
Outcast (01-04-2010)
post #3 of 11 (permalink) Old 01-04-2010, 08:43 PM
gassernomore's Avatar
The block heater is right by the oil filter. See if the cord is there. It usually is and goes up by the headlight. If you don't have the cord you can check at Geno's Garage.
99 2500 4x4 / Edge EZ / Isspro Fuel Gauge / Turbo Timer / Raptor 150 / Scan Gauge II
06 2500 4X4 / Edge Attitude / Straight Piped
gassernomore is offline
The Following User Says Thank You to gassernomore For This Useful Post:
post #4 of 11 (permalink) Old 01-04-2010, 08:46 PM
Retired Engineer
Courierdog's Avatar
See http://www.cumminsforum.com/forum/6-...-location.html
2007 6.7 L, 2500 QC, Laramie, SB, 3.42, Mag-Hytec, 68RFE, Harvard 750 Bypass Oil Filter, Patriot Blue, 4X2, Michelin LTX Summer, Michelin X Winter, Raider Canopy, HERD Bumper, Espar Cab Heater, Sirius, Smarty 25ME, SS636, WCC Intake Manifold & 3.5 inch Boost Tube, Donaldson 100580, PMT Gauge Set, Smarty, Optima Red Top Batteries, Have Truck, Will Travel
Courierdog is offline
The Following User Says Thank You to Courierdog For This Useful Post:
post #5 of 11 (permalink) Old 01-04-2010, 09:23 PM Thread Starter
Found it. Thanks Guys
Using the Cold Weather Plug in Location link I went right to it.
Thank You again!
Outcast is offline
post #6 of 11 (permalink) Old 01-04-2010, 09:30 PM
Just Another Slow VP
little red cummins's Avatar
whats cold weather for ya?
my ol girl starts just fine down to -15*F
plus i dont got anywhere to plug it in so im SOL
02 2500 4x4 6spd. SO VP. SouthBend DD 3600. FASS 150. HOT Juice (No Tap). Smarty. 100hp Injectors. HTT 3pc Exhaust Manifold. BHAF. BD Super B. Haisley Head Studs. CPP 115lb Springs. Hamilton HD Rods. 4th Gen Steering. PacBrake PRXB Exhaust Brake. Firestone Ride Rite. Custom Traction Bars. 50gal Transfer Flow Tank.
little red cummins is offline
post #7 of 11 (permalink) Old 01-04-2010, 11:19 PM Thread Starter
This is my first winter with a diesel truck. I live in Arkansas, were forecast to get down close to Zero which is much colder than normal for us. It must be that global warming!
So far this winter it has not given me any hint of a problem. Just trying to be over prepared. What kind of fuel additive do you use in -15 weather?
Outcast is offline
post #8 of 11 (permalink) Old 01-04-2010, 11:24 PM
Are you not running any additive now? No 2 stroke?
post #9 of 11 (permalink) Old 01-04-2010, 11:26 PM
haha i didnt mean anything by it, just funny to me anyways to hear guys that wanna plug in there truck when it dips down into the 40s. i used PowerService in the White bottle all year round. just keep a bottle or 2 of PowerService 911 in the back seat or toolbox just in case. knock on wood i havent had any problems with gellin
post #10 of 11 (permalink) Old 01-05-2010, 10:09 AM Thread Starter
What is the 2 stroke doing?
Does the regular diesel additive not have sufficient lubricant in it? At what temperature does diesel start to gel?
Thanks
Outcast is offline
post #11 of 11 (permalink) Old 01-05-2010, 10:18 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
I would use some diesel kleen in the white bottle for cold winter's. I plug my truck in when it gets down below 45 or so just so the truck is half way to opperating temp and I have heat when I get in it.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is offline
