ABS problems - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 12-28-2009, 02:18 PM Thread Starter
ABS problems
Hi guys,
i have a 2000 dodge 2500 diesel 4x4. my ABS light park break light came on and my speedomiter and cruise quit all at once. i checked my fuses and connections and they seem fine. i am ready to pull out my hair! any help would be great!
Thanks a bunch
power is offline
post #2 of 5 (permalink) Old 12-28-2009, 02:32 PM
Diesel Filled Veins!
Sandman76's Avatar
Doing a search would probably net you a lot more info, but in short probably the speed sensor on the top of the rear differential (speedo not working points to this one). There are two more speed sensors in the front hub assemblies but you don't wanna know what those will run you to fix.
#3 ATS Stage IV - So Far So Good
EPA "Race Tuned" with EFI Live By DaveMatthews, Edge CTS; Fred Goeske dually spacers
2008 - - M - E - G - A - DUALLY - -
Sandman76 is offline
post #3 of 5 (permalink) Old 12-28-2009, 03:36 PM Thread Starter
thanks a bunch, i will try that
power is offline
post #4 of 5 (permalink) Old 12-28-2009, 04:57 PM
mine did the same thing, replaced the vss (on the rear diff) and i was good to go
1998.5, 24v, 3/4 ton, QCLB, Goerend 47RE w/ billet input, triple disk converter, 4.10's, Airdog 150, DDP 150's, super B special, Edge comp, egt/boost/trans gauge, 5" straight pipe, K&N intake, 4" lift, 35" STT
Trailblazer332 is offline
post #5 of 5 (permalink) Old 12-29-2009, 09:16 AM
99BigRed's Avatar
same here.
99 QCLB Red 4x4 53 block,nv5600,263k miles.Edge,ATS Manifold,Head Studs,Pacbrake,SouthBend Clutch,Raptor 150,Transferflow tank,BHAF, DAP injection pump,75HP Dap injectors
99BigRed is offline
