Center driveshaft bearing 2001 - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 12-20-2009, 02:09 PM Thread Starter
josterbauer's Avatar
I have the center bearing taken off the 01 Quad cab long bed. I have the spicer # off the center bearing 231212 is the number. I looked up the number online, and says that it is discontinued. I can not find anything that this bearing cross references to. Any one else have trouble finding a bearing for an 01?? Or does anyone know what bearing will cross reference this one.
06 Mega Cab 4X4 Auto
04.5 ctd cc, auto, 4x4
Sold - 2001 qc, auto, 4x4 lb
josterbauer is offline
post #2 of 18 (permalink) Old 12-20-2009, 08:09 PM
call napa or carquest and its a called a carrier bearing! and only get premium stuff so you can forget about it!
CUMSonStrokes is offline
post #3 of 18 (permalink) Old 12-20-2009, 08:35 PM Thread Starter
Napa has the right looking bearing with the exception of the inside diameter. They have the bearing that is 1.43" ID. The one that I took off has an ID of 1.5748". It is actually called a center support bearing. The carrier bearing is in the differential I believe.
post #4 of 18 (permalink) Old 12-20-2009, 11:02 PM
dodge24's Avatar
Let us know if you find the correct one. I have tried to get one from online in the past and it's been wrong every time. Hope you get it figured out!
01 Dodge Ram 2500 4x4 Auto 35" Toyo MT on XD Hoss Wheels
High Tech Turbo - Dynomite Diesel Performance - Thuren Fab - AirDog - Smarty - SOLD
dodge24 is offline
post #5 of 18 (permalink) Old 12-20-2009, 11:07 PM Thread Starter
Will do. I am going to try to find one locally as well as online. I will keep posting when I find out something new.
post #6 of 18 (permalink) Old 12-21-2009, 12:01 AM
Travass 76's Avatar
i had the same problem but found the solution. if you really cant find it you can call a company called driveline service of fresno. it is located in fresno ca and they also have a polyurathane insert to replace the rubber surrounding the bearing. its the heavy duty solution that you can forget about.
2004/4x4/nv5600/ crew cab/flatbed/ smarty SO-6,edge cs monitor, phatshaft 62 turbo, southbend,airdog 165,AFE intake, 5"
Travass 76 is offline
post #7 of 18 (permalink) Old 12-21-2009, 01:03 AM
totalloser's Avatar
There are carrier bearings on the carrier of the differential, but the center support bearing is also referred to as a carrier bearing.
If you have trouble with the bearing jumping out of the bushing, a simple solution is to wrap a couple loops of galvanized hardware wire around the front part where it sneaks out and twist the end.
01 100hp tips EZ *hybrid* 4"ss BDbrake &steering brace "t"steer delphi tapped &rammed manual CAD 3.55's LSD, 1.375 nv5600/241HD Valair single pc rear ds 265x70r19.5 big rigs 3rd gen brakes Ugly black and thrashed!
totalloser is offline
post #8 of 18 (permalink) Old 12-21-2009, 11:06 AM
theres always the dealer
post #9 of 18 (permalink) Old 12-21-2009, 01:36 PM
Joe_T's Avatar
another alternative would be to get the correct diameter from the dealer and then go to rock auto.com and match it up with the right one from them, i got alot of parts for mine from them with good luck, sans carrier bearing which came from the local dealer
Joe_T is offline
post #10 of 18 (permalink) Old 12-21-2009, 01:57 PM
kstinson's Avatar
NATIONAL Part # HB88508AB {Ball Bearing; Bore=1.5748" Inner Race Radius=0.06"}
Bearing & Assembly; Spicer 1410 & Cleveland 055 Series; Brg. I.D. 1.5748" / 40mm; Centerline 2.284" / 58mm
$47.79
Found it at Rockauto.com
2000 Black Dodge Ram 3500 Dually 5.9l 24-Valve, NV5600 6-Speed, Edge Juice/Attitude, AirDog 150, Hydroboost to keep the front end lubricated ;-)
kstinson is offline
post #11 of 18 (permalink) Old 12-21-2009, 03:30 PM Thread Starter
$47.79
I found that one as well, but it is the wrong one. I just got back from Proven Force Driveline and Clutch. This is a local shop by me, and I found the exact one that I took out. It is a Spicer 211963-1x metric. The one above has a centerline of 2.284", the spicer has a centerline of around 3.125". I figured I would post the part number for anyone that needs to find this part.
post #12 of 18 (permalink) Old 12-22-2009, 01:45 AM
dodge24's Avatar
Thanks! That's what I was looking for!
dodge24 is offline
