Identify a transmission from pictures? - Dodge Cummins Diesel Forum
 2Likes
  • 1 Post By DodgeMech
  • 1 Post By bigfish95971
post #1 of 11 (permalink) Old 03-20-2017, 07:23 PM Thread Starter
moonshadows's Avatar
I've got an 01 that needs a trans (like 50% of the rest) the truck is rough and I don't want to put the cash out for a rebuild so it's parked!!
One o the local Facebook trading groups just popped up with a trans "they think is a diesel 94-03" I know there where several different variations so that statement is BS
is it possible to ID a trans from pictures?
How can I tell if it's a diesel trans?
What do I need to look at?
Thanks to anyone that can help, it's two hours away so I'm hoping to get as much info as possible before I go
http://i50.photobucket.com/albums/f3...pseduumbcn.jpg
http://i50.photobucket.com/albums/f3...psxgzadaxd.jpg
http://i50.photobucket.com/albums/f3...pswnlcajun.jpg
http://i50.photobucket.com/albums/f3...psrofhixs1.jpg
I added more pictures showing the plugs --- scroll thru
1990 ram D350 dually 12v automatic
2001 ram 2500 quad cab 4x4 24v automatic
1970 Chevy suburban 12v 5spd 2002 dodge chassis <project>
moonshadows is offline
post #2 of 11 (permalink) Old 03-20-2017, 07:34 PM
DodgeMech's Avatar
so, by my observation, that's definetely a chrysler 4x4 re(i think, don't believe the rh has the plug pointing up for the gov pressure solenoid and transducer) trans
and it even has what looks like an aftermarket torque converter in it
but, i can't tell just from outside if it's a 47 or 48 re
though i'm sure someone here can
moonshadows likes this.
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
The Following User Says Thank You to DodgeMech For This Useful Post:
moonshadows (03-20-2017)
post #3 of 11 (permalink) Old 03-20-2017, 07:45 PM Thread Starter
Thanks hope I can narrow down a bit more!!
post #4 of 11 (permalink) Old 03-21-2017, 08:46 PM
its definitely a 47re. If it out of a V10 or Diesel, we cant tell you. That would take a valve body inspection along with cutting the TC open to inspect the stator.
JohnLegend0409 is offline
post #5 of 11 (permalink) Old 03-22-2017, 12:48 AM
47RE up to 02(maybe 03) are pretty much the same mechanically. 98.5-2000 had one set of electronics and 01-02 had different ones. What is wrong with yours? Contrary to some, they are pretty tough if ran near stock HP, except for electronics and clutch wear. You can get old retired guy rebuild for under a $1000 inc parts. You can fix certain problems for a lot less, often yourself..
Larry Meier likes this.
99 2500, Quad cab, 4x4 47RE, BD pressure lock on it, small BD 90/140 chip on the VP 44 connection plug, 17" 3rd gen wheels.3.55 diffs. Ruenell front bumper and warn winch, Rancho adj shocks. 603k miles.
bigfish95971 is offline
post #6 of 11 (permalink) Old 03-22-2017, 09:57 AM Thread Starter
Mine ran out of adjustment on the bands a couple years ago, now there is not second gear at all it'll run in first and reverse, I was able to run First hard and go really way in second till it shifted into third but it's done now. It needs built!!
Thanks for the info everyone
post #7 of 11 (permalink) Old 03-22-2017, 03:31 PM
Moon, Did you ever replace governor pressure sensor an solenoid? Any metal in the pan? Some aftermarket bands are available that can be replaced without trani removal.
post #8 of 11 (permalink) Old 03-23-2017, 10:47 AM Thread Starter
Yes replaced those parts and there is / was metal in the pan, if I was gold panning I'd have been rich lots of flakes!!
post #9 of 11 (permalink) Old 03-23-2017, 07:48 PM
Well sounds like tear down time or at lease a slide in band. If you have the bucks at least consider a retired trani guy rebuild, about a $!000 most places. AAmco is about $3000 and aftermarket goes up from ther.
post #10 of 11 (permalink) Old 04-09-2017, 11:06 AM
Dang, BigFish - I had my 98 - 24v/47RE/2WD at McClellan in a hanger for over a year. I wish I knew then, that you were in Sacto, I'd have taken you out to lunch to get your advice on my transmission issues...and thanks for the great info you post in these threads.
Larry Meier is offline
The Following User Says Thank You to Larry Meier For This Useful Post:
bigfish95971 (04-09-2017)
post #11 of 11 (permalink) Old 04-09-2017, 03:09 PM
Hey thanks, I use McClellan VA for my medical care.
