1998.5 dodge 3500qc 5.9 - Dodge Cummins Diesel Forum
 1Likes
post #1 of 33 (permalink) Old 03-19-2017, 10:58 PM Thread Starter
Red face 1998.5 dodge 3500qc 5.9
i have a code 1689 truck will start and run has dead pedal as i hear it called lol im a newbie here the check engine light is on this truck is my deceased fathers truck it was given to me to fix and drive i have ran thru the diagnostic tests for the ecm not communicating with the fpcm i have read the threads here that say the vp44 is bad or going bad it makes me wonder sing the unit will start up and run if u hit the throttle it will go to 1200 and run smooth as glass no miss or anything i have pulled the ecm tio have it tested i can get it cked for free any other help will be greatly appreciated it is a 24 valve also
angelchaser1970 is offline
post #2 of 33 (permalink) Old 03-20-2017, 01:29 AM
PTSCummins's Avatar
Check your fuel pump relay. When that relay fails it can set 1689 and exactly what you're experiencing.
Sent from my ASUS_Z012DC using Tapatalk
1999 Ram 2500 QCLB - SO 24V in front of NV4500 and SB DD 3250. Fresh rebuild with ARP studs, CR head, 150HP F1s, Raptor 100, Quadzilla Adrenaline and soon to be compounds.
PTSCummins is offline
post #3 of 33 (permalink) Old 03-20-2017, 01:41 AM Thread Starter
Is that the one in the fuse box or is there another relay that i do not know about
post #4 of 33 (permalink) Old 03-20-2017, 11:00 AM
PTSCummins's Avatar
Yep in the fuse box. Make sure it's not failing intermittently
post #5 of 33 (permalink) Old 03-20-2017, 12:19 PM
Monstermaker's Avatar
I think you can swap the horn relay in its place to check?
Or just throw a new one in anyway because they don't cost much.
'99 QC 4x4 Dually, Quadzilla not wiretapped, DAP 150hp VCO7x.010s, HX35, 47RE triple disc billet everything, lockup switch, 4.10s, Gear Vendors OD, Kelderman Air Ride, Alcoas, 4" pipes, BD brake, Fass Titanium 95, Hellwig sway, steering brace, airbags
Monstermaker is offline
post #6 of 33 (permalink) Old 03-20-2017, 07:22 PM Thread Starter
i did swap them but no change but i do have a new one to throw
in anyway i talked to a injection service today and they say its the vp44 pump probably they told me 1150.00 exchange
post #7 of 33 (permalink) Old 03-22-2017, 01:15 AM
How has it ran prior? other symptoms. Check and clean all battery terminals and harness plugs. Check apps for smooth output on pin 3 for smooth operation from about .5v at idle to about 3.8v at WOT.
Recheck of other codes.
Any wait to start light or other ecm issues?
99 2500, Quad cab, 4x4 47RE, BD pressure lock on it, small BD 90/140 chip on the VP 44 connection plug, 17" 3rd gen wheels.3.55 diffs. Ruenell front bumper and warn winch, Rancho adj shocks. 603k miles.
bigfish95971 is offline
post #8 of 33 (permalink) Old 03-22-2017, 02:12 AM
PTSCummins's Avatar
Stupid question, but are both engine grounds connected, and the ECM ground right above the starter connected? I'd be checking that first before you drop money on a new pump
post #9 of 33 (permalink) Old 03-23-2017, 11:13 PM Thread Starter
i will be checking all the grounds this weekend its been colder n rainy since im garageless if its nice out ill be looking at it more
post #10 of 33 (permalink) Old 03-27-2017, 10:05 PM Thread Starter
ok update i checked the grounds found the ground wire to the fule pump relay is not getting a full ground on the 85 pole in the pd box repaired the ground but the lift pump is also not working i checked for power and with the key on only getting 8 volts did some reading found out that it only powers up for 2 seconds when u key on and when u hit the starter it powers up for 25 seconds but the lift pump when its plugged in i dont hear it make any moise or hum or anything when u key on or try to start the truck i got to that point and it started raining will mess with it more this weekend. if it is a power issue can i reroute the power to it
angelchaser1970
post #11 of 33 (permalink) Old 03-27-2017, 10:27 PM
Does your Wait To Start Light come on immediately when you first turn the key to on?
post #12 of 33 (permalink) Old 03-28-2017, 05:22 AM Thread Starter
Yes it does come on immediately
angelchaser1970
