Blue pump blues - Dodge Cummins Diesel Forum
Old 05-03-2007, 02:49 PM   #1 (permalink)
Doug_TX's Avatar
Blue pump blues
Installed a Holley Blue because as I drove along with the stock LP the FP would abruptly drop for no apparent reason (in a constant speed cruise). Installed the Blue and all is well for a while. Now I get the same thing. But the FP drop makes no sense as before. In a cruise (running 0 to 1 psi boost) the FP will suddenly drop. If I gun it the FP jumps back up. So long as I'm pushing some boost I have good FP. I'm running the Blue through a relay getting the switch signal from the power wire to the old LP (which is now bypassed and unplugged).
Question: Could it be the ECM isn't sending a constant 'signal' to run the LP?
'02 2500 HO 6 speed 4x2.
Not bad for a first diesel........
Doug_TX is offline   Reply With Quote
Old 05-03-2007, 03:02 PM   #2 (permalink)
dieselbeef's Avatar
thats how i got mine setup. it doesnt do that. maybe the pump is goin into bypass and its stickin a little. guage issue?
02 quad cab shortbed, silver, iis silver 62, iis hrvp, god only knows what inj im running right now, 6'' single cat stack, black beadlock rims, 315's, holley black
http://www.youtube.com/watch?v=OUFOk2rlvto
dieselbeef is offline   Reply With Quote
Old 05-03-2007, 04:15 PM   #3 (permalink)
SuperDuperMod
rbmchief's Avatar
my truck does the same exact thing. replaced the fuel filter and it went away for about a month. now its doin it again.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin stanadyne. [url]
rbmchief is offline   Reply With Quote
Old 05-03-2007, 06:18 PM   #4 (permalink)
Banned
Cavitation Cavitation is NOT your VP-44's friend! - TDR Roundtable
mysterync is offline   Reply With Quote
Old 05-03-2007, 06:27 PM   #5 (permalink)
SuperDuperMod
rbmchief's Avatar
i read that. I don't know why it just all of the sudden started doing it.
Old 05-03-2007, 07:52 PM   #6 (permalink)
Ontario Chapter President
CumminThru's Avatar
Originally Posted by mysterync View Post
NowTHAT'S some good info....:thumbsup
Thanks Gary!!
Dan - Ontario Cummins Crew President Ontario Chapter Facebook - Dan
GONE but never forgotten - 2001.5 24V QC SLT Laramie 2wd 47RE/3.55, LB, ICEBOX w/4510, FBD 4" turbo back w 5x18 SS tip, silencer ring MIA, FASS 150, IIS HRVP, DiPricol 30 psi FP guage, 1 qt 2 stroke EVERY tank!! 16.5481 @83.29mph on 7/7/07
My new ride - 09 Ram, For NOW .... it's got one of them damn HEMI'S in it.
CumminThru is offline   Reply With Quote
Old 05-03-2007, 08:23 PM   #7 (permalink)
Doug_TX's Avatar
I have the pump mounted on the frame rail just ahead of the tank. So I doubt it's cavitation.
Old 05-03-2007, 08:45 PM   #8 (permalink)
CumminThru's Avatar
My "stock replacement" has been "relocated" to the rail in front of the tank and is crappin out off and on according to the guage OR so I thought until I saw this. :fist:
Gary's first video shows EXACTLY the same thing I'm experiencing. All sorts of pressure then a sharp drop and the dreaded "dead pedal" is soon to follow bump it into neutral turn the key off and on and it's fine BUT really is an issue making a left turn and NEEDING the juice to get going and it's not there!!
I've been seriously looking at the FASS pump in the same location with new lines (now) all the way thru to hopefully take any possibility of restrictions thats as I understand it are the major cause of cavitation.
I had planned on getting a pump believing the rrplacement had served its use and was just plain due, keeping the stock filter canister for it's extras and I dont ever plan on 500+ HP so why spend the extra for the FASS fuel and water gizmo NOT that I think it's a bad thing but it has its purpose's.
NEW, Larger fuel lines now that I see what restriction can do will be added into this project as well :thumbsup
Now having said all that I wonder if possibly a "new stock replacement pump" with new lines all the way would be OK and possibly solve these issues??
It would save me the extra expense of a more expensive pump or do I wanna cheap out and possibly end up gettin all greasy doin a VP replacement anytime soon??
Old 05-03-2007, 11:25 PM   #9 (permalink)
Tech Specialist
WorkhorseDiesel's Avatar
That was one very good and interesting bit of information Gary. This has been a long debated issue and I believe you've put the final nail in the coffin of any cavitation doubters. You've just given me one more reason to feel good about switching to a Walbro when I did. Great work and information. I believe that your video should be posted in this forum as a tech article and as a MUST SEE so that all 2nd gen owners can see the inherent problem with an OEM Carter configuration.
:thumbsup
2001.5 White 2500 Reg-cab • 4x4 • NV4500 • 4.10 • BHAFWALBRO GSL392Edge Juice + AttitudeVALAIR HD OFEScangauge II • 315 Cooper S/T's • Optimas • custom black grille & blue graphics • ** Diesel Fuel Treatment is here **
WorkhorseDiesel is offline   Reply With Quote
Old 05-03-2007, 11:43 PM   #10 (permalink)
GottSoot's Avatar
sounds kinda like your getting some air in the line somewhere, do you have some of the orginal fuel lines?
Billings Mt. Home of the Dirtymax!! 9.46 149MPH
GottSoot is offline   Reply With Quote
Old 05-04-2007, 11:34 AM   #11 (permalink)
Doug_TX's Avatar
I'm using part of the steel line and new hose. So I am using some of the original line, just none of the original hose.
Old 05-07-2007, 02:37 PM   #12 (permalink)
eflynn1959's Avatar
Not to steal your post but I have the same problem. have stock fuel pump and Holley blue running. My pressure use to be 19 to 20 PSI at idle. drop maybe 5 psi WOT. Friday looked at pressure down to 10 psi at idle drops down to 5 at wot changed fuel filter nothing changed still at 10 and 5. I'm thing the stock pump quit working all together and is blocking the fuel to the injector pump where my gauge is hooked up
2001 Dodge Ram FP Guage 4" exhaust Straight thru.Vulcane big line , Holley Black as the pusher pump
eflynn1959 is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
