P1690 - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 12-18-2009, 12:07 PM Thread Starter
j_ray05's Avatar
P1690
Hey guys. A buddy of mine called me up this morning and his truck is loping really bad at about 1400 RPM at idle. When stopped and rev the engine up it still runs pretty crappy, but when driving and under a load he says it runs perfect. I havent seen the truck when running like this since hes on the other side of the state right now, just goin off of what he says.
He pulled up the code P1690 which I find as--CKP sensor does not agree with ECM CKP sensor.
Its a 2000 3/4 ton, 5-speed, with a PPE lift pump, has good fuel pressure. Edge comp and superchip but they are both turned off and edge is unplugged now.
1999 2500 Quad Cab-Short bed-4X4-5 speed-Ranch hand Grill Guard-B&W Hideaway Goose neck-12mm P Pump- Contag1ous Diesel 6x.014-Isspro Gauges-Hamilton 188/220-Common Rail Tappets-A1000-ARP Head Studs-S463-Valair Triple Disc
2005 3500 Crew cab-Long bed-Dually-6 speed-5" turbo back exhaust-Smarty
j_ray05 is offline
post #2 of 9 (permalink) Old 12-18-2009, 12:53 PM
gassernomore's Avatar
Replace the sensor and it should be good to go.
99 2500 4x4 / Edge EZ / Isspro Fuel Gauge / Turbo Timer / Raptor 150 / Scan Gauge II
06 2500 4X4 / Edge Attitude / Straight Piped
gassernomore is offline
post #3 of 9 (permalink) Old 12-19-2009, 01:52 AM Thread Starter
j_ray05's Avatar
what sensor would that be?
j_ray05 is offline
post #4 of 9 (permalink) Old 12-19-2009, 09:59 AM
The crankshaft position sensor. Have your buddy clean ALL the grounds -batteries, behind the starter, and under the drivers side battery traym and any others that he might fine and see iof that fixes the problem first.
post #5 of 9 (permalink) Old 12-19-2009, 04:02 PM
Osar's Avatar
The CKP is located above and behind the starter, which has to be removed to change it.
2000 2500 4x4, QC, LB, rebuilt auto trans w/shift kit, ISS Pro EV2 gauges, AD150, Edge Comp, BHAF, Chevy RWC.
Osar is offline
post #6 of 9 (permalink) Old 12-20-2009, 02:52 AM Thread Starter
j_ray05's Avatar
ohh alrite Thanks, I'll pass it on.
j_ray05 is offline
post #7 of 9 (permalink) Old 12-20-2009, 10:20 AM
Mopar1973Man.Com
Mopar1973Man's Avatar
If that doesn't work you might check the wiring... Here is a write up fot checking that...
VP44 Error Codes
Mopar1973Man is offline
post #8 of 9 (permalink) Old 12-21-2009, 02:22 AM Thread Starter
j_ray05's Avatar
well, I let him know and he called me back today and said he went into mopar mans website and followed the directions on what wires to inspect and check out...he says everything checked out as should be so is kinda thinking its the ECM he also changed the crank sensor and had made no difference.
j_ray05 is offline
post #9 of 9 (permalink) Old 12-21-2009, 03:13 AM
only check for the ecm is verify resistance from ground at connector to ground. and verify +5v at connector.
99 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch. am boost/pyro gauges, gs FP gauge, raptor 100, hypertech III. 53 block, (355k miles, still no cracks
)[knocks on wood
Dracozny is offline
