Issue after auto to Manuel conversion - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 02-15-2017, 12:22 PM Thread Starter
Hi guys. Check engine light is on after 2 weeks of the conversion. Tach will drop to 0 at times then work. I've noticed when it does this I do lose some power. Truck is stock except for 4" exhaust and isspro pyro gauge. I bought a 98 donar truck and had a local tranny shop do the conversion. The bad part was the donar truck is a 12 valve so no computer. Just wondering if there's a simple fix or if I have to do a ecm swap. The cruise also does not work. Thanks for any input.
Sent from my SCH-S968C using Tapatalk
FarmwithIH is offline
post #2 of 17 (permalink) Old 02-15-2017, 01:56 PM
Crank sensor going out?
2000 Dodge Ram 2500 5.9 CTD, 4X4, Auto, FASS 95, Isspro Gauges, Mag-Hytec DD pan. 2016 2500 4X4
Diesel_dog1 is offline
post #3 of 17 (permalink) Old 02-15-2017, 02:10 PM
gh0stman's Avatar
That's what it sounds like to me.
As for your cruise...you need to run the wire for the NSS to the switch on the clutch pedal and ground it. Im sure they grounded it during the conversion and you can probably start the truck while its in gear.
You shouldn't need a ECM. As it has nothing to do with the transmission. My truck is going on 2 years after the conversion and no check engine lights or anything. Some trucks handle it well others do not. Your best answer is to rent or borrow a smarty and flash a manual tune to the truck. This will most likely solve your problem.
2000 Ram 2500 QCLB-Quadzilla Adrenaline, FASS Titanium 95 GPH, 4 Inch Diamond Eye Duals Donalson M090544, BHAF, MoparMan Crank Case Vent Mod, NV4500 swap, SB3250-6, DAP 7x0.010, 4th Gen Center Console, Optima Yellow Tops
FIL - 07.5 Ram 2500 Megacab - Ctrl Alt Deleted/ 97 Ram 3500 2wd dually, remote fuel filter, Jacobs exhaust brake
gh0stman is online now
post #4 of 17 (permalink) Old 02-15-2017, 02:14 PM Thread Starter
They hooked up the clutch safety switch. So I can not start in gear
post #5 of 17 (permalink) Old 02-15-2017, 02:18 PM
gh0stman's Avatar
Do you run the vacuum assisted cruise or electronic cruise? ie what year is your truck.
post #6 of 17 (permalink) Old 02-15-2017, 02:52 PM Thread Starter
What does the nss stand for? Do u need a special code reader for these or will a standerd one work. Would like to see what it reads. It would throw a code for the crank sensor correct? Not saying u guys are wrong. Also a couple times on a warm start it just cranked and cranked. Waited about five min then it fired. Forgot about telling u guys that. Thanks again for the input
post #7 of 17 (permalink) Old 02-15-2017, 02:56 PM Thread Starter
Truck is a 98.5 with the 24 valve
post #8 of 17 (permalink) Old 02-15-2017, 03:01 PM
gh0stman's Avatar
NSS= Neutral safety switch (when grounded it tells the vehicle its not in gear and safe to start)
It needs to be ungrounded for cruise to work, otherwise it thinks its in neutral.
As for prolonged cranking sounds like there is to much fuel pressure during cranking.
As for a code reader as long as it reads and clears codes you will be fine.
post #9 of 17 (permalink) Old 02-15-2017, 03:19 PM Thread Starter
Where would the nss switch be? So I need a wire from that to the clutch switch?
post #10 of 17 (permalink) Old 02-15-2017, 05:08 PM
gh0stman's Avatar
There is a 3 wired plug that went to your auto. The putter two are the reverse lights the middle one is the nss. Run a wire to the clutch safety switch and from there to ground.
post #11 of 17 (permalink) Old 02-15-2017, 05:35 PM Thread Starter
Ok thank u on the cruise issue. Will tackle that when it warms up a little outside. Will be checking code in a few days also.
post #12 of 17 (permalink) Old 02-15-2017, 11:11 PM
Most always when the Tach does that it is the crank sensor on any 98.5 to 00. Not related to conversion.
99 2500, Quad cab, 4x4 47RE, BD pressure lock on it, small BD 90/140 chip on the VP 44 connection plug, 17" 3rd gen wheels.3.55 diffs. Ruenell front bumper and warn winch, Rancho adj shocks. 603k miles.
bigfish95971 is offline
