Vacuum Pump - Dodge Cummins Diesel Forum
post #1 of 1 (permalink) Old 12-06-2009, 10:28 AM Thread Starter
OILCANCUMMINS's Avatar
Vacuum Pump
I Started To Loose My Hvac Controls 4x4 And Cruise I Found Out Here ,it May Be Vacuum Related. I Found The Pump To Be Very Weak, Little Vacuum. So With The Truck Running I Sprayed Seafoam Penatrating Oil In Pump Out Put Port. What Ever It Loosened Up It Cured It. Everything Has Been Working Great For About A Week Now. Hope It Lasts These Pumps Are Expensive.
2000 2500 EDGEW/ATT,STAGE 3 INJECTORS,AMSOIL FLUIDSW/BYPASS,AMSOIL AIR FILTER W/HOMEMADE HOLDER,HOMEMADE INTAKE,AIR HORNS,5''STACKS,
TORQUELOCKW/BRAKE DEACTIVATED,NEW FRONTEND
OILCANCUMMINS is offline
The Following User Says Thank You to OILCANCUMMINS For This Useful Post:
runit02 (12-08-2009)
