on/off throttle jacking/hammering/jerking noise/feel - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 11-23-2009, 11:39 PM Thread Starter
First off, some pedigree info: My truck is a 2001 5spd manual, 2wd, with just under 80,000 miles on it.
The problem:
When I'm cruising, or acclerating in gear and let off the throttle (no clutch, just let off) there is a sound almost like 2 pieces of metal banging together. This happens at highway speeds in 5th, or at neighborhood speeds in 2nd/3rd/etc. If I abruptly let off the throttle there's a banging/jerking/clang that wasn't there before. I can hear it and feel it in the cab.
If I push in the clutch before letting off the throttle all is smooth. I think this is a driveshaft/U joint issue. What do you guys think?
thanks!
2001 Dodge 2500 Quad Cab Longbed 5sp manual, stock for now
sweatmachine is offline
post #2 of 25 (permalink) Old 11-23-2009, 11:55 PM
HeavySweep's Avatar
U joints or pinion bearings. Most likely U joints though
2001 2500 QCLB, ATS stage 1, Scheid 100's, Edge Juice, Banks 4", Thuen parts and Carli parts
HeavySweep is offline
post #3 of 25 (permalink) Old 11-24-2009, 12:20 AM
edgecummins5.9's Avatar
set ur parking brake and check em out
99 2500 sport..nv4500 swap, edge juice
*HOT*, 5 inch tbe, Green intake, Valair 600hp single, Airdog150, afe blade runner, .093 Tubes, II 64/71/14 & 200's. ARP head studs, Leveled bilstein 5100's
edgecummins5.9 is offline
post #4 of 25 (permalink) Old 11-24-2009, 12:37 AM Thread Starter
how do I do that?
I'm a damn good motorcycle mechanic, and I have plenty of tools.
How complicated of a job is this? Or, how much should I expect to pay for a shop to fix this?
thanks y'all.
post #5 of 25 (permalink) Old 11-24-2009, 12:54 AM Thread Starter
I got under the truck and grabbed 2 handfulls of drive shaft, no give. This was in my driveway on an incline and the truck is in gear, so that might be messing me up.
post #6 of 25 (permalink) Old 11-24-2009, 01:07 AM
notomas's Avatar
put your parking break on, block the tires and then check the driveline with the truck in neutral
97 2500 4x4, excab , K&N intake, 4" exhaust, egt,boost,tranny temp on the pillar, 5 star viskus torque converter, converter lock up, stage lll rebuild, #100 plate, 3gsk, boost 30psi, starwheel forward and Smoke screw adjusted for power
notomas is offline
post #7 of 25 (permalink) Old 11-24-2009, 01:34 AM Thread Starter
ok, stupid question, but with the parking brake on, what's the point of blocking the tires? and how do I check the driveline? Just grab it and shake for all I'm worth?
post #8 of 25 (permalink) Old 11-24-2009, 02:16 AM
dodge24's Avatar
Check the u-joints and see if they are bleeding rust. I had the same condition you are describing on my 06 Dodge and even though the joints felt tight in the truck as soon as I got them apart it was clear what the problem was. The grease was gone and the needles were nothing but rusty powder. New joints solved the problem! You may also want to consider a fifth gear nut problem. I have no experience with the NV4500, but if you are getting noise in fifth gear it may be worth a little bit of research. Good luck!
01 Dodge Ram 2500 4x4 Auto 35" Toyo MT on XD Hoss Wheels
High Tech Turbo - Dynomite Diesel Performance - Thuren Fab - AirDog - Smarty - SOLD
dodge24 is offline
The Following User Says Thank You to dodge24 For This Useful Post:
sweatmachine (11-24-2009)
post #9 of 25 (permalink) Old 11-24-2009, 08:16 AM Thread Starter
thanks guys. This is def not a 5th gear issue. It does this in every gear, that's why I'm thinking driveshaft, plus I can hear it.
post #10 of 25 (permalink) Old 11-24-2009, 12:06 PM Thread Starter
ok I crawled under there (banged my head on the trans mount, then banged it on the street, now I have 2 big knots on my head, dammit) and I figured out where the problem is. It's at the first U-joint right off the transmission. I'm not to familiar with this, so excuse the lack of correct termage...
here's a pic:
The red arrow indicates where the problem is. It's like a bushing is supposed to be there and it's gone, allowing for some free play in the U-joint which is making the noise and feel I'm experiencing.
What is the fix for this, and how difficult will it be to do myself? I've got plenty of tools and I have tomorrow off work. Another option would be to bite the bullet and pay a shop for this, any ideas on approx what I should expect to pay?
thanks guys!
post #11 of 25 (permalink) Old 11-24-2009, 12:16 PM
DieselAutoPower.com
patracy's Avatar
iTrader Score: 5 reviews
The easiest way to fix it for you would be to take the driveshaft out. It's only 4 bolts on the pinion. Then the slip yoke slides out. Put something under it to catch oil. Then take the shaft to a local shop and have them swap the joints for you. I recommend picking up joints from the dealership as autozone and other parts stores joints are crap.
patracy is offline
post #12 of 25 (permalink) Old 11-24-2009, 12:44 PM Thread Starter
what's the correct term for the part I need? I called the Dodge dealer and the guy wasn't too sure about what I needed, he thought it was the "Extension Housing Bushing" and it was like $75. I sent him the same pic as I posted here and I'm waiting for his response.
