oil leaking from crank case breather tube - Dodge Cummins Diesel Forum
Old 11-21-2009, 09:05 PM   #1 (permalink)
i have a 98.5 3500. the truck is leaking oil from the crank case breather on the back of the motor. when i run the truck normally it barely leaks. actualy its a small drip about 16 seconds apart. when im pulling my trailer it dumps out. the other night i went about 400 miles and went through four gallons. also the kid who works on it for me got it to dump oil when he held the throttle at 2500 rpms. a few people said its a broken ring. the only reason i am questioning the thought of a broken ring is the fact that the truck runs perfect. no smoke, no performance loss, nothing out of the ordinary in the drive or idle except the oil dumping out. anyone else experience this? anyone have any suggestions before i have the motor ripped apart?
mjttransport is offline   Reply With Quote
Old 11-21-2009, 09:17 PM   #2 (permalink)
VP Moderator
dozer12216's Avatar
Do the AC door controls work??? Does cruise control work????
If the vacuum pump does not pull a vacuum, it becomes a air pump into into the crankcase. Since it is a positive displacement pump, the faster the engine runs the more air is pumped inro crankcase and blown out the breather.
2008 3500 stock QCLB dually Inferno red. Toys of all sizes:Fuel injected Rampage, Grader, 1586 tractor, 60K genset, Honda Foreman ATV, and more. Back in business with a Hitachi EX270LC excavator. The dirt slinging has begun with 50+ acres to clear.
dozer12216 is offline   Reply With Quote
The Following 2 Users Say Thank You to dozer12216 For This Useful Post:
countrymoparguy (02-04-2010), mjttransport (12-04-2009)
Old 11-21-2009, 10:11 PM   #3 (permalink)
now that i think about it the heat is only coming out the defroster no matter what setting it is on. i have not used my cruise in a long time but i did recently go to use my 4wd and it would not engage and i was told it would caused by a vaccuum issue. man i hope your right. its killing me to think i will have to rip apart a cummins with 180k. thanks i will let you know.
Old 11-22-2009, 11:51 AM   #4 (permalink)
hey dozer, i did find a vacuum line disconnected. the heat controls are working fine now. i drove the truck for a while and then revved it and held it 2500 for about ten seconds. all i got out of the breather tube was a small drip. im going to let the truck sit for a while and get a good reading on the oil then clean the back and bottom and run it hard on the highway to check for any oil underneath or loss of oil. so far its looking good. thanks again for your help. if this worked your a lifesaver and just saved me thousands. thanks again
Old 11-22-2009, 10:41 PM   #5 (permalink)
Where are these hoses located that were disconnected?!!?!? I am having the same problems.
2006 2500 Quad cab 4x4 5 speed | K&N Intake
Ag2011 is offline   Reply With Quote
Old 11-22-2009, 11:30 PM   #6 (permalink)
it was the hose that went from the power steering pump to the tower on the firewall just over the brake fluid
Old 11-22-2009, 11:34 PM   #7 (permalink)
VP Moderator
dozer12216's Avatar
Correction. The hose goes t vacauum pump which is mounted PS pump and gear housing. The alunimnun thing.
Old 11-23-2009, 10:01 AM   #8 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Ditch the crankcase vent and try my mod...
Crancase Vent
It helps...
Mopar1973Man.com -=- Michael Nelson -=- 2O8-628-3645 -=- If you need a hand with your Dodge Cummins give me a shout...
AirDog 150, RV275 Injectors, Edge Comp (Tapped), Straight Pipe 3" Exhaust, BHAF, Exhaust Brake, Timbo APPS, Southbend Con OFE, ScanGauge II, DiPriocl Gauges, High idle / MPG fooler, etc.
(Posted with Ubuntu Linux 12.04)
Old 12-04-2009, 09:33 PM   #9 (permalink)
since dozer advice i have gone 2000 miles hauling three cars or trucks. i was towing three cars at a time for half the miles and my foot trailer the other half. i cant believe it but i only went through a half of a quart of oil. dozer thank you so much. you were a life saver on this one. i cant believe a vacuum line caused such mayhem. so howw are you with the death wobble? even if you dont know anything about it you still the man. thanks again. if i ever haul a load in your area i owe you a beer.
Old 12-04-2009, 10:14 PM   #10 (permalink)
edcasey's Avatar
It's not as good as a beer but if you go to one of Dozer's replies and click the "Thanks" button it will add to his thanks count.
2000 3500 4x4, auto 4.10,BHAF, 4" MBRP, Power Puck, Converted to SRW, Dual Walbro 392's w/2 mic Cat filter, DiPricol FP, PSC DSS, billet trans
edcasey is offline   Reply With Quote
Old 12-04-2009, 10:16 PM   #11 (permalink)
Thanks for the follow up!
2001 QCSB 4x4 - NV5600 - Super B turbo - FBD 100hp injectors - BHAF - 4" exhaust - AirDog & big fuel line - BD Trackbar - Diablo Power Puck - Valair SD clutch - ScanGaugeII - 53 block, 130,000 mi
Contrite is offline   Reply With Quote
Old 12-04-2009, 10:19 PM   #12 (permalink)
didnt know that but i just clicked it.
