| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
Heat exchanger removal
I just read pattracy's thread on the heat exchanger he moved. I just put a new trans in and just ran barbed fittings on the trans out to a hayden trans cooler. What does the heat exchanger do, and do I/should I use it ?
"We don't drive Dodges, we run Cummins. " |
#2 (permalink) |
![]() Join Date: Sep 2008
it uses the engine coolant to cool the trans temp. It works well if it is not stopped up.
"No eye has seen, no ear has heard, no mind has conceived what God has prepared for those who love him" ![]() 87 Toyota pu (DD)99 SWB Ram 1500 318 5 speed (cummins swap comming) 94 Dakota 408 stroker, ross pistons, bigs carb, indy intake, MSD, W2 heads, 904 auto 3k stall, 3.90 gears 99 short bed cummins, raptor, edge juice/attitude, 100hp over stock VP44, 100hp injectors, 4" exhaust, HE351 more to come.. 99 Yamaha FJR1300.(stock) |
#3 (permalink) |
It also helps warm up the tranny when its cold.
01 2500 ext. Cab 6spd Long box with flat bed. Edge Comp Drag, ATS exaust Minifold, 5" turbo back to 7" miters, K&N intake, Jammer 4's, south bend 3600 DD, Glaciar fuel pump, 295/70/17 toyo M/T's. |
#4 (permalink) |
Would it be better, as in more effective to run an affter market cooler, or should I go back to the heat exchanger.
#5 (permalink) |
2001 Cummins
![]() Join Date: Sep 2009
If there is nothing wrong with your stock unit, I would use it. Not sure the after market users are worth the investment.
2001, 2500 Ext Cab, Banks Exhaust, 4.10 gears, Auto, BAHF, Puke Bottle mod (mopar1973mans), Airdog 150, |
#6 (permalink) | |
I would start with a transmission temp gauge and determine whether or not you need additional cooling.
2000 Black Dodge Ram 3500 Dually 5.9l 24-Valve, NV5600 6-Speed, Edge Juice/Attitude, AirDog 150, Hydroboost to keep the front end lubricated ;-) |
#7 (permalink) |
I put a new trans in, and just liked the idea of an after market cooler, and simplifying all the hoses, but I need to mount a fan on my after market unit, I mounted it under the driver side floor board, outside of the frame rail. It got hot enough to kick out of OD tonight running down the highway at about 75, scared the bejebus out of me when it down shifted.
#8 (permalink) |
I can't find any threads on other installs of after market coolers, does any one know of any ?
#9 (permalink) |
Try this Heat exchanger relocation
#10 (permalink) | |
Super Moderator
![]() ![]() Join Date: Oct 2007
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, Tunnel Ram Intake plate, Byrd's intake Horn, HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost & Drive pressure gauges, fuel pressure gauge, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
