best tires for mud and slop - Page 2 - Dodge Cummins Diesel Forum
post #13 of 53 (permalink) Old 11-15-2009, 10:55 PM
Apparently you dont understand that you cant really have both. You either have something thats great in the mud and wont leave you in a field and something that sucks on the highway. Or you get stuck and run great on the highway.
Buy a 2nd set of wheels and swap out when you tow or split the difference with a tire like the KM2.
Jason
2015 F250 Lariat Ultimate CCSB 6.7PSD
2014 Ram 1500 hemi/8spd/3.92/traded
2014 CCSB 2500 Tradesman. 3.42/68RFE/traded
JasonY is offline
post #14 of 53 (permalink) Old 11-15-2009, 10:58 PM
Mike516882's Avatar
I run Dunlop mud Rovers, and they are good in the snow and mud... i have around 20k on them and still have a good bit of tread left... If i were to do it again i would get the Mickey Thompson MTZ... They are great street, mud, snow, and cow sh!t id imagine.
2007 Ram 2500, Sterling Grill/Badges, RCLB, Auto, Charcoal Grey, 2.5" Leveling Kit, 315/70/16's, AFE Intake, 6" Black stacks,Bully Dog & Edge EZ, Edge CTS Gauges, 20% tint, 7'6" Western Ultramount, LED Strobes.
Mike516882 is offline
post #15 of 53 (permalink) Old 11-15-2009, 11:33 PM
Future Fly Boy!
Gixxer_750's Avatar
mtz, toyo mt, those cooper mt's...not sure if they come in load e in that size but im sure you could find one of them that does...good road manners and will still chew through the slop...too bad the ground hawgs arent in your size...those things rip and wear like iron cause the compound is pretty darn tough
'01 4x4
Gixxer_750 is offline
post #16 of 53 (permalink) Old 11-16-2009, 01:32 AM
kstinson's Avatar
The more aggressive the tire the worse its going to wear. A tire that does good in the mud isn't going to wear well on the highway. Personally I would stick to a more aggressive all terrain if the mud isn't that bad, it would have better wear characteristics than a true mud tire.
2000 Black Dodge Ram 3500 Dually 5.9l 24-Valve, NV5600 6-Speed, Edge Juice/Attitude, AirDog 150, Hydroboost to keep the front end lubricated ;-)
kstinson is offline
post #17 of 53 (permalink) Old 11-16-2009, 09:16 AM
sledneck696's Avatar
Go with Toyo MT I think you can get them as a E too.
Also I got pro comp x-terrains and there good in the mud and actually really good no the road too and are wearing very well.
2001 q-cab 4x4 sport 6 speed swap, 3600SB clutch, SB hydraulics, B1/B2 twins, Mach 7's, Edge juice w hot, fire rings, ARP's, Rips Boot Kit, airdog, BD short shift, Hurst shifter, Dipricol Optix boost gauges, subs, dvd, Fabtech 5.5" dual shock lift, dual shock steering stabilizer, 5" curved top stacks
SOLD
sledneck696 is offline
post #18 of 53 (permalink) Old 11-16-2009, 09:23 AM
When I'm in the market for new tires I review The Tire Rack survey results as a source for additional information. Just go to the Tire Rack home page, then pick the category of tire you're looking for from the "Survey Results" link on about the middle of the page on the left and go from there.
Tried to provide you all a link, but it keeps getting hijacked...
whoaru99 is offline
post #19 of 53 (permalink) Old 11-16-2009, 10:34 AM
Kbrogger's Avatar
My last two set of tires have been Bridgestone Dueler Revo's. Been great tires. Aggressive, but certainly not a mud tire. They don't howl going down the road, and I got 67k miles out of the last set. I end up backing a 16' trailer into some soft places when I'm delivering cabinets with it and they work well.
2001-2500, 4WD, H.O., 6spd, Edge comp, Smarty, FASS 150/150, South Bend con OFE clutch, MBRP 5" exhaust, AEM Brute Force HD
Kbrogger is offline
post #20 of 53 (permalink) Old 11-16-2009, 10:52 PM
Its either one or the other man. The better the tires are on road the worse off road they will be. An all terrain tire will only work for so long. It will chew up the ground because they WILL gum up so you will have to spin the sh!t out of the tires to clean them. the first time you get stuck you will wish you got the mud tires. You need to have tires with some big deep lugs that will self clean so you don't have to spin them. Maybe you should look into some of the tall n skinny military tires. Or the Ground Hawgs, they are a tuff tire that are good in the mud and they have some heavy ply tires as well.
If it were me I would sacrifice the nice riding long lasting road tires for some noisy mud tires, I know how it is being stuck in mud overnight freezing my ball$ off. It ain't no fun!!!
Slipster is offline
post #21 of 53 (permalink) Old 11-16-2009, 11:03 PM
Just Another Slow VP
little red cummins's Avatar
im runnin procomp mts. they do good when haulin. ive grossed over 25k with em. and the do good on the roads. and ive raced acrossed the pasture with em and they do good in the mud and goo.
02 2500 4x4 6spd. SO VP. SouthBend DD 3600. FASS 150. HOT Juice (No Tap). Smarty. 100hp Injectors. HTT 3pc Exhaust Manifold. BHAF. BD Super B. Haisley Head Studs. CPP 115lb Springs. Hamilton HD Rods. 4th Gen Steering. PacBrake PRXB Exhaust Brake. Firestone Ride Rite. Custom Traction Bars. 50gal Transfer Flow Tank.
little red cummins is offline
post #22 of 53 (permalink) Old 11-16-2009, 11:16 PM
DELETE YOUR TURBO!!!!!
WATERLOO49's Avatar
iTrader Score: 4 reviews
MICKEY THOMPSON MTZ!!!!!!!!!!! by far the best tire made pricy but worth every penny, oh and they plow through cow sh!t guarenteed
POWER TRIP Pulling Team
Sponsored by Banghart Diesel & Performance and Big Tints.
2015 Nebraska Bush Points Champion
WATERLOO49 is offline
post #23 of 53 (permalink) Old 11-16-2009, 11:16 PM
01blackcummins's Avatar
Toyo MT in the 265-75R16 they come in a E rating and they are quiet on street with good manners, ive hauled trailers and hay with them no prob. You do notice the tread blocks flex a little under torque, i have 22k on them now they are rated for 40k atleased and they are a MT, do good in snow and mud. I like them and would recomend them, if youre talkin real deep nasty mud maybe go with a little wider size. Hope this helps man!!
sold-01 2500 4x4 QCLB H.O. 6spd, new- 04 3500 qclb H.O. 6spd 4x4 araid CAI 4 in turbo back exhaust with 6in tip fass 150 pump smarty jr quadzilla boost fooler and a couple of guages
01blackcummins is offline
post #24 of 53 (permalink) Old 11-17-2009, 01:03 AM
We use the Toyo MT's and still get stuck. The last two winters we have just left the 1994 cummins feed truck chained up on all fours all winter unless we need to go to town with it. Been lucky and haven't stuck it yet with chains. Take ten minutes-then the chains are off. Just part of life around here-just the way it is. Or, like you said earlier-"there is always the tractor".........
2002 SLT 6-speed HO SB/QC 4x4, 3.55's Anti-Spin, BHAF, Triple A-Pillar Isspro Gauges (FP,Boost,Pyro) , MBRP 4" Exhaust, Airdog 100, Smarty Revo, Edge Comp, Silencer Ring MIA
winch_warrior is offline
