Old 11-06-2009, 08:43 PM   #1 (permalink)
johnsol0's Avatar
changing fluid
Whenever u change ur transmission fluid does all the oil come out to like the torque converter oil too. I was just wondering. Cuz the lady at the part store said a service change is 4 quarts and to change the whole thing is 16.9 And i have a 47re.
johnsol0 is offline   Reply With Quote
Old 11-07-2009, 05:06 AM   #2 (permalink)
Horse Power JUNKIE
Nitrous340's Avatar
It depends on how long it has been sitting. A few hours and the converter prob hasn't drained all the way. I have no idea how you could get away with just 4 qts. If I drop the pan, with my Hytech DD pan I usually go through 10-14qts.
2001 2500 4x4
PDR HX-40, PSC brace, Hamilton 110 springs, Fluidamper, ARP studs, Adrenalin, DDP 150, custom intake, 4" straight pipe, AIRDOG 150, BD black FP, Suncoast billet trans, 3-disc converter, 3rd Gen Brakes, Thuren 3rd Gen track bar. RIP grandpa "Red" 10-11-08
WAGNAAR MOTORSPORTS
Nitrous340 is offline   Reply With Quote
Old 11-07-2009, 07:52 AM   #3 (permalink)
A "normal" service is from 5-7 quarts plus filter. If you loosen the ten 7/16 capscrews holding the vb a couple turns you will get far more fluid out. Make sure and retorque.
2000 Big Blue Beast 3500 SLT 2WD heavy hauling auto, stage 1 injectors, 232K miles and still growing.
Toys from .049 airplane to 1248 CI D8H dozer. Wanna play!
dozer12216 is offline   Reply With Quote
Old 11-07-2009, 10:12 AM   #4 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Yeap even my vapacity chart shows the same thing...
Fluids and Capacities
LOL! I've always done that too. So I could get that little extra out too. Also I never hurry a fluid change I always allow for it to stop dripping.
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
Old 11-07-2009, 10:19 AM   #5 (permalink)
jl99cummins's Avatar
drink a beer till it stops drippin' thought i would throw that in
99 cummins 4" exhaust, comp, smarty revo, bhaf w/ heat shield, airdog 150, autometer gauges, silencer ring mia, hbs leveling kit, 125's, ready for trans and turbo
jl99cummins is offline   Reply With Quote
Old 11-07-2009, 10:24 AM   #6 (permalink)
I would need to drink a 12 pack...
(Since I don't have a Auto Trans)
When I chang engine oil in my truck I pull the plug and the oil filter and leave it till it quits dripping. At this point I do other thing like rotate tires, adjust parking brake, check the brake pads, check all other fluids, grease the front end, vacuum out the cab, then... I might eat lunch... Then check and see if it quit dripping...
Old 11-07-2009, 08:57 PM   #7 (permalink)
johnsol0's Avatar
i preciated guys i figured it out today. it took 6 quarts. With no leaks. I dont know what that lady was thinkin when i bought my filter. Good then i went ahead and bought extra oil
