Ok, first, THANK YOU ALL FOR YOUR PAST HELP ON THIS ISSUE! This is an update and I am looking for feedback!!!!
My WIF indicator came on. I drained and changed my filter system, after, the lift pump would not run, installed a new FASS system, still not enough pump power ( only 8.7 vdc) I was told the ECM module is bad, another $1000, rather, I had them install a relay off the engniton key, relay kicks on and runs the new FASS fuel pump just fine, ALL SYSTEMS GO!!!!! Put 15-20 trips for about 150 miles, starts and runs great and no errors.... What should I expect in the near/far future? Any thoughts???? Thanks
