| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
need help asap !!!!!
ok i drained the fuel filter water separator housing and alot of diesel came out, now the truck wont start. is it normal for diesel to drain out of the separator housing?
2002, 4x4, auto, ext. cab |
#5 (permalink) |
01 Cummins
![]() Join Date: Jul 2009
Hey, Yeah it's normal for fuel to come out, but it doesn't effect starting, usually! Did you change fuel filter or anything??? Was the truck running fine before you worked on it?? Later, Winslow
Black 2001 Dodge Ram 2500 Shortbed, Ext. Cab 4x4, 5.9 24 valve, TCW-3, 2-cycle oil in every tank, 54 Block!! , NV 4500, 3.55 gears, Anti-spin, B&W Turnover Gooseneck Hitch, Autometer Ultra-Light Boost, EGT, and Fuel pressure gauges, Valair 13" Kevlar/Ceramic 3400 lb Single Disc Clutch, Valair Upgraded Hydraulics, Edge Comp Programer, 3" Straight pipe for now, BHAF with custom 7075 T-6 Heat Shield, AFE Torque Tube, Air Dog II DF-165 with custom cover!!
#6 (permalink) |
01 Cummins
Hey, You might want to check for codes just to be safe! OBD II Error Codes Does the truck have the stock lift pump? Later, Winslow
#7 (permalink) |
no i didnt change the fuel filter, i was just draining the water bcuz i heard your suppost to every once in a while, but i forgot to close it back up for about 30mins. yeah it was running good before i washed the engine and drained the water separator
#10 (permalink) |
01 Cummins
Hey, Well that's a bad code to have (P1689)!!!! You could have bigger issues! ![]() Read this: VP44 Error Codes If you didn't close it up for 30 mins, the housing is dry. You might want to try and bump the start a few more times. Later, Winslow
| The Following User Says Thank You to Prowelder For This Useful Post: | kummins84 (11-06-2009) |
#11 (permalink) |
Location: lower central NY but in the sunshine state right now
take a 3/4 wrench and loosin the # 2 and 3 in injector line on the block and try and start th truck this will bleed the system as soon as the truck fires turn it off and tighen the injector lines you should be good
99 3500 auto 2WD DRW mosty stock 5" straight pipe 100 raptor fuel pump silencer ring m.i.a.261k and counting http://myspace.com/jitt08 and my email is jitt08@myspace.com
