Old 11-06-2009, 07:34 PM   #13 (permalink)
jitt08's Avatar
Location: lower central NY but in the sunshine state right now
telling you to keep trying to turn the motor over and over is not a good idia killing batts will soon happen or worce bad starter
99 3500 auto 2WD DRW mosty stock 5" straight pipe 100 raptor fuel pump silencer ring m.i.a.261k and counting http://myspace.com/jitt08 and my email is jitt08@myspace.com
jitt08 is offline   Reply With Quote
Old 11-06-2009, 07:35 PM   #14 (permalink)
01 Cummins
Prowelder's Avatar
Originally Posted by kummins84 View Post
no!!!!!!!! well im gonna bump it a few more time to see what happens.
Hey,
If that doesn't work, try loosening the injectors as mentioned above and see what happens.
After you bump it a while and it won't start (hopefully it does) you could flip the drain valve again and make sure there is fuel in there!
Good-Luck,
Winslow
Black 2001 Dodge Ram 2500 Shortbed, Ext. Cab 4x4, 5.9 24 valve, TCW-3, 2-cycle oil in every tank, 54 Block!!, NV 4500, 3.55 gears, Anti-spin, B&W Turnover Gooseneck Hitch, Autometer Ultra-Light Boost, EGT, and Fuel pressure gauges, Valair 13" Kevlar/Ceramic 3400 lb Single Disc Clutch, Valair Upgraded Hydraulics, Edge Comp Programer, 3" Straight pipe for now, BHAF with custom 7075 T-6 Heat Shield, AFE Torque Tube, Air Dog II DF-165 with custom cover!!
Prowelder is offline   Reply With Quote
Old 11-06-2009, 07:36 PM   #15 (permalink)
01 Cummins
Prowelder's Avatar
Hey,
Not cranking it, bumping it to get the lift pump to run!! Big difference!!!!!!!!
Later,
Winslow
Old 11-06-2009, 07:42 PM   #16 (permalink)
98whitelightnin's Avatar
Like jitt said, youve got air in the lines and youve got to get it out before it will ever start. Your gonna have to loosen a couple injector lines at the head and blead the air out. Dont engage the starter more than 30 seconds at a time and let it cool down for a minute or so between.
98 24v, 2500 sc, auto, 4x4, LO 359hp/744tq
03 2500 4d, 6speed, 4x4,
"Well oil beef hooked"
98whitelightnin is offline   Reply With Quote
The Following User Says Thank You to 98whitelightnin For This Useful Post:
kummins84 (11-06-2009)
Old 11-06-2009, 07:47 PM   #17 (permalink)
ok i bumped acouple of time and it started. i turned it off and now when i turn the key the wait to start light doesnt come on at all like it should.
2002, 4x4, auto, ext. cab
kummins84 is offline   Reply With Quote
Old 11-06-2009, 07:53 PM   #18 (permalink)
01 Cummins
Prowelder's Avatar
Hey,
How long did it sit before you turned the key back on???
Later,
Winslow
The Following User Says Thank You to Prowelder For This Useful Post:
Old 11-06-2009, 08:12 PM   #19 (permalink)
like two mins, i went back out there and the light came back on like should. I love this place, glad i became a member
Old 11-07-2009, 01:32 AM   #20 (permalink)
01 Cummins
Prowelder's Avatar
Hey,
Good to hear!!!!! The grid heater only kicks on if the IAT (intake air temp) is low enough!
BTW- Glad to have you aboard!!!!!!
Later,
Winslow
Old 11-07-2009, 10:40 AM   #21 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Wow! what a mess...
Ok... Here we go...
1. Reprime the fuel system. The reason for this is when you drained the fuel filter housing you allowed air to enter the fuel system. The injection pump is like the brake system it can't pump air bubbles. So hence the truck won't start.
Reprime Fuel System
2. As for that P1689 error code here is som diagnostic information about that code and hopfully its not a failure problem. Check your fuel pump relay if you pulled this relay (or the relay was bad, or fuse blown) the power supply to the VP44 was dissconnected hence tripping the code.
VP44 Error Codes
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
Old 11-07-2009, 02:19 PM   #22 (permalink)
Yeah, bleed the fuel lines as kummings84 states. If you can't get air out of the system, make sure your lift pump is pushing at least 8PSI. If you got fuel, bled lines and are still not starting, let us know.....
1999 dually 4x4, Edge Level 5, DD 3 injectors, Full ATS Trans and Co-Pilot, FASS150, Custom TDR Cam, ATS 3-piece Header, Custom Down Pipe, Banks High Flow Intake, Propane, 4:10 Gearing, AmSoil front to back, 5-inch exhaust, 1500 watts (I can't hear the engine)
bmac is offline   Reply With Quote
Old 11-07-2009, 02:19 PM   #23 (permalink)
Would an aftermarket fuel system like an airdog still be affected by that fuel relay, or is that relay by passed with a different relay? I have a friend pulling this code and he has a FASS system.
'00 2500 Auto QuadCab ShortBed 86k- BD performance elbow, 4" straight piped exhaust, AirDog 100 w/custom bracket, Low Fuel pressure sensor, autometer boost and pyro guages, Van Aaken CPC controller, 55 block.
UtahDodgeCummins is offline   Reply With Quote
