Old 11-06-2009, 05:33 PM   #1 (permalink)
Need Help!!! Truck Wont Start
Today I decided to get rid of the crankcase breather canisterRerouted to the back of the engine. I got some engine degreaser and cleaned the area around the canister and then I washed the engine at the car wash. I started the truck and went home but now it wont start. The engine turns like it wants to start but it wont. Any ideas what could be wrong? has anyone ever done the same thing? thanks guys
2002, 4x4, auto, ext. cab
kummins84 is offline   Reply With Quote
Old 11-06-2009, 09:24 PM   #2 (permalink)
gassernomore's Avatar
Have you tried to see if you have any codes? Turn key on, off, on, off, and on. Write down the numbers that flash up on the odometer. Wait for it to say "done" twice. Repost those numbers if you have some.
99 2500 4x4 / Edge EZ / Isspro Fuel Gauge / Turbo Timer / Raptor 150 / Scan Gauge II
06 2500 4X4 / Edge Attitude / Straight Piped
gassernomore is offline   Reply With Quote
Old 11-07-2009, 08:09 AM   #3 (permalink)
Frequently the wiring harness connector at rear of engine(cowl) injests water and shorts things out. Turns truck to junk, but will offer $500.00 if otherwise in good condition.
Or disconnect connectors and blow dry with compressed air.
Look for codes also as previouslly suggested.
2000 Big Blue Beast 3500 SLT 2WD heavy hauling auto, stage 1 injectors, 232K miles and still growing.
Toys from .049 airplane to 1248 CI D8H dozer. Wanna play!
dozer12216 is offline   Reply With Quote
Old 11-07-2009, 10:28 AM   #4 (permalink)
www.Mopar1973Man.com
Mopar1973Man's Avatar
Check common stuff...
Check your error codes
OBD II Error Codes
Check fuses
Check relays
Check wiring connectors for moisture (as Dozer suggested!)
Remember to smack the THANKS! button for those that helped you or you think that post is helpful to others!
