Old 11-04-2009, 09:02 PM   #1 (permalink)
BD Waste Gate
What does this BD Waste Gate Do? And does it work? Is it worth it? I have AFE Stage II Cold air, and straight piped. Thanks
idahocountryboy is offline   Reply With Quote
Old 11-04-2009, 09:21 PM   #2 (permalink)
MR.B's Avatar
I had one on my stock turbo It helped a little. your better off spending your money on other things. First you need a better lift pump like fass airdog or raptor and fuel pressure gauge. as far as your turbo get a boost elbow or j hook. it depends on which turbo you have they will help with boost but then you will need a boost fooler or a chip with one built in because the truck will see an over boost and defuel. fill out your sig so we know what truck you have.
2000 4x4 auto aem workhorse intake cfm+ s300 3rd gen track bar conversion bd steering stabilizer
4"exhaust rv275 fass 95 Adrenaline w/pulse
MR.B is offline   Reply With Quote
