Old 11-04-2009, 07:35 PM   #1 (permalink)
xarcticzonex's Avatar
control arm bushings?
im looking for the moog part number for the control arm bushings in my truck and when i look online its only post one bushing lower RWD? is it the same bushing? the moog part number im looking at is K80366 does anyone have a idea if this is the right one?
02 4X4 slt SO stock engine 4 inch turbo back strait pipe airdog 150 with DS V thanks to jkidd silencer ring MIA new dieselpro VP FP gauge 3rd gen TB kit soon to come 98-99 front suspension
xarcticzonex is offline   Reply With Quote
Old 11-04-2009, 08:50 PM   #2 (permalink)
98whitelightnin's Avatar
I will find out for you tommorow as my dad works for Oreilly's and got me mine.
98 24v, 2500 sc, auto, 4x4, LO 359hp/744tq
03 2500 4d, 6speed, 4x4,
"Well oil beef hooked"
98whitelightnin is offline   Reply With Quote
Old 11-06-2009, 03:04 AM   #3 (permalink)
jason's Avatar
I just went to Dunks performance and got the beefiest and adjustable control arms for about 360. Never been happier.
2000,4x4, quad, 315procompAT's, XZT+ to big hoss level 5,banks high ram,banks wastegate,100hp injectors,4"tbe,TAG,ranch hand bull nose,leveling kit, auto with hughes perf. TC and VB,pillar gauges- trans,pyro,boost,fuel press, BHAF, 2 LP's @28psi
jason is offline   Reply With Quote
Old 11-06-2009, 06:36 PM   #4 (permalink)
My dad said that you can only get the whole upper control arm with bushings. My 98 has different part numbers for the bushings too but I guess since yours is an 02 and you have the non cad.
Old 11-07-2009, 03:12 AM   #5 (permalink)
well they came iun sets of 2 so i hope there the right ones if not oh well back to the drawing board
Old 11-07-2009, 05:46 AM   #6 (permalink)
I had to use a press to press the old ones out, good luck.
Old 11-08-2009, 05:40 PM   #7 (permalink)
well old one out and new ones in. come to find out there not all the same. the top ones are different and i need to order the whole top control arm...thats some bullsh!t! so i got the new lower bushings in( and the bolts on the diff side of the lower control arms i had to cut out with a torch... yay what fun ) and i have the upper control arms out and im taking them to middleton and mead tommarow to get them rebushed if not looks like some more custom fab work that i need to do so wish me luck
Old 11-08-2009, 05:40 PM   #8 (permalink)
i used a hammer worked fine for me
Old 11-08-2009, 06:20 PM   #9 (permalink)
I tried with a hammer and torch for a while but the press got them out pretty easy.
Old 11-09-2009, 12:03 AM   #10 (permalink)
hmmmm a few wcks and they were out for me a few good wacks and the new ones were in the biggest B!TCH was i has to cut out the pitch adjustment bolts with a torch and i gotta goto a spring shop tommarow to have the upper control arms rebushed cause the ones i got were wrong and im not paying 200 for 2 control arms when rebushing them will cost 50 max
Old 11-15-2009, 02:09 PM   #11 (permalink)
ok so come to find out dodge has not released the pat.# on the bushings so no one has them after market but the 99 year bushings work but you have to open the colar on the inside of the bushing. i took mine to a machine shop to spread the colar cause it was hardned steel. i couldnt do it i was limited on tools . i didnt think it was gonna be this big of a pain in the @ss but its all togther now rides alot better even better since i just installed the SS 3rd gen track bar. but she still wonders a bit . when you step on the fuel she wants to turn left. when you take you foot off it it turnes to the right almost like the rear is shifting but its not
Old 11-15-2009, 03:06 PM   #12 (permalink)
Mine does that a little bit too and I just put on the BD's trackbar kit. I'm thinking my sway bar end links don't look so hot.
2001 QCSB 4x4 SLT 6spd manual - Skyjacker 3" lift kit - 4" exhaust - AirDog - ScanGaugeII confirmed 21.5mpg - BD Trackbar Conversion - Banks Big Hoss module (soon to be replaced by an Edge Comp) - running 305/70/16's - Valair clutch & flywheel on the way
Contrite is offline   Reply With Quote
