Old 11-04-2009, 01:13 PM   #1 (permalink)
Found a truck but have a question
I found a truck that has an automatic trans and 4.10 rear end? I was wondering if that gear ratio will really kill my MPG? I also was wondering if i were to put a bigger tire on it would the bigger tire cancel out the gear ratio and give me a better MPG reading.
Hopefully a 3rd or 2nd generation cummins! Extended cab, shortbox
abe568 is offline   Reply With Quote
Old 11-04-2009, 01:45 PM   #2 (permalink)
CoalRoller's Avatar
4.10's will definitely lower your fuel mileage (I can't say how much) and going to a taller tire would compensate for the low gear ratio, but the big tires are going to be heavier than stock so if they did help the MPG I wouldn't imagine it would be much. Also a wider tire gives you less MPG.
Another thing to think about is the suspension. Bigger tires on the front puts more stress on your ball joints, tie rod ends wheel bearings, etc...
2002 6-speed, 5 inch straight pipe, Icebox, Edge Comp/Smarty. Isspro pyrometer, mechanical boost guage & electric fuel pressure gauge. FASS 95, Valair kevlar/ceramic clutch...
CoalRoller is offline   Reply With Quote
Old 11-04-2009, 02:48 PM   #3 (permalink)
macattack_ga's Avatar
How are you going to use the truck?
1997 3500 ExCab 4x4 Auto 3.55 (KDP Tabbed, EGT & Tranny Gauged, Fuel filter "PrimeLoc"ed, oil Amsoil Dual By-passed) 3 switch WVO setup (tank/filter/tank), PCS Boxed
1981 BJ42 (Full Alum Tub, 3B, H42, split case, 4.11 open)
macattack_ga is offline   Reply With Quote
Old 11-04-2009, 02:49 PM   #4 (permalink)
the truck will be my daily driver with probably pulling once or twice a month.
Old 11-04-2009, 03:14 PM   #5 (permalink)
Poor Man Built
Dreadnaught's Avatar
i get around 18mpg on the freeway with 4.10's and 315 70r17's. thats only going 65. towing a 20ft flatbed with 4 quads on it, i get around 15mpg. going 60-65 mph.
empty going 70-75 i get around 16mpg. that couple mph extra may get you there faster, but its actually what kills your mpg.
2004.5 Dodge Ram 3500 4x4 4 door, Short bed, Auto, 315X70 R17 Hankook RF10's, Recon Cab lights.
Silencer MIA, S&B CAI, 5" Expandit TBE, DiPricol (EGT, Boost, Pyro), Edge J/A
Early 2000 Ford F-350 Reg Cab Lb Dually 2006 Headlights and Grille
AFE Stage 2 intake, DP Tuner (20, 40, 80, 140), Custom exhaust, ITP Over Boost Annihilator, Derale Atomic Trans Cooler, 5" turnout stacks
Dreadnaught is offline   Reply With Quote
Old 11-04-2009, 03:20 PM   #6 (permalink)
hmm..ok. as long as i get somewhere between 16-20 mpg i would be happy. I need something that gets good fuel mileage for being a truck lol. I need a truck but a bigger part in my decision making is which setup would get me better mpg. I will eventually be putting bigger tires on the rig like a 285 or 305 tire so maybe the 4.10s would be better for me.
Old 11-04-2009, 03:29 PM   #7 (permalink)
Poor Man Built
what are you planning on pulling? how much weight are we talking?
Old 11-04-2009, 03:45 PM   #8 (permalink)
farm equipment, combine heads, hay racks, skid steers, etc.
Old 11-04-2009, 03:54 PM   #9 (permalink)
Poor Man Built
if its not long distance stuff, maybe look into swapping 3.73's in later on down the road. it won't hurt your mileage too bad while towing, and it will help when the truck is empty.
Old 11-04-2009, 05:53 PM   #10 (permalink)
well i dont want to buy a truck that im going to have to swap out the gears in right away. There are two trucks im stuck between. both 2002 2500s auto extended cabs, this one is green with a short bed leather interior for 13995 with 155k miles. The other one is a gray one long bed with 165k miles for 12995. Im not sure on the gray ones gear ratio though.
Old 11-04-2009, 06:08 PM   #11 (permalink)
little red cummins's Avatar
haha i got my truck with 3.55s and 265s ....then i went to a 285 tire.....now im at 315s and i do tow 4-5days a week and gross between 25-30k and im swappin 4.10s in it here soon.
so if yer thinkin of goin to a 33'' tire. id stick with the 4.10s if yer gunna tow
2002 2500 4x4 6spd. 3rd Gen. Recon Cab Lights. SB single disk. HOT edge J/A. FASS 150. BHAF and Outer Wear. Silencer ring MIA. 6'' aussies. leveled. 315 procomp m/t. B&W Gooseneck Hitch. Cobra 29 w/ dual 4ft Firesticks. Cumstom Front Bumper. Soon to have 4.10s
little red cummins is offline   Reply With Quote
Old 11-04-2009, 11:00 PM   #12 (permalink)
Poor Man Built
go with the long bed. i have a short bed and am constantly wishing i had a long bed.
