View Poll Results: How do you shift?
Use Clutch for every shift 136 73.91%
No clutch for shifting 48 26.09%
Voters: 184. You may not vote on this poll
Old 11-06-2009, 11:53 PM   #61 (permalink)
Originally Posted by JasonY View Post
Generally you *should* always use the clutch on a synchronized transmission, doesnt mean you have to. but it only takes a few mis shifts to really take a toll on the teeth of the synchro.
Jason
synchros DONT have teeth, a synchro is basically a small clutch to match the rpm of the 2 gears before the teeth engage on the shaft so it wont grind.
rolland40 is offline   Reply With Quote
Old 11-07-2009, 12:00 AM   #62 (permalink)
they look toothed to me
Rebuilding an NV4500 Manual Transmission - Four Wheeler Magazine
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100.
Dracozny is offline   Reply With Quote
Old 11-07-2009, 12:27 AM   #63 (permalink)
if those are teeth then why doesnt it grind, you can see a friction material on the inside of those rings, the teeth fix the synchro to the gear
Old 11-07-2009, 12:59 AM   #64 (permalink)
The synchronizer ring (#7) in the diagram is what is normally called a synchro ring - it's the part that usually wears out. The synchronizer sleeve of the synchronizer (#1) slides back and forth on the synchronizer hub (#3), which is the part that is attached to the output shaft by he barely visible splines on the inner diameter. The synchro ring (#7) "rides" on the conical shaped part (#6) of the gear (# 5). When you shift into a gear, the synchronizer sleeve (#1) is moved toward the gear (#5). As it moves, the small teeth (#9) engage the teeth (#4) on the synchro ring, which causes the synchro ring to rotate at the same rate as the synchronizer assembly (#1 & #3) which are splined to each other as well as the output shaft. As synchronizer sleeve (#1) continues to move toward the gear, the inside of the synchro ring (#7) is pressed up against the conical shaped part of the gear. This causes the gear to match speed with the synchronizer, and once the speeds are matched, the synchronizer sleeve continues to slide toward the gear, engaging the teeth on the side of the gear.
How a Transmission Works
Great write up on how a standard box works.
Jason
2001.5 Ext. Cab Short bed 4X4-315 BFG AT's/AEM HD intake/MBRP 4"/Silencer ring M.I.A/Raptor 100/new VP44/Mag deep trans pan/Edge EZ/RV275's/Quad Commander/Kool-Vue power/heated tow mirrors
JasonY is offline   Reply With Quote
Old 11-07-2009, 11:25 AM   #65 (permalink)
JD3500's Avatar
I use the clutch in my pickup truck.
I never use the truck on the kenworth, or any of our other big rigs. its a good way to screw up soem synchro's
1999 3500 DRW. New Holley Blue lift, and VP44
stock. BHAF, Straight Pipe. Plans for Fass gauges and chip. Pulls 33ft alumascape 5er
JD3500 is offline   Reply With Quote
Old 11-07-2009, 05:41 PM   #66 (permalink)
Ops
Ops's Avatar
If you do it right, no harm will be done. If you are doing it right, you can shift gears with one or two fingers.
Been a while since I had a stickshift in my own vehicle, but I floated them all the time, never blew a manual trans in any truck I've owned.
Ops
01 QC, tow package, 4X4, Edge EZ, 4:10s with LS, 5" straight pipe. DSS steering brace, AGR steering box. Holley Black on the frame rail, ISSPRO fuel pressure guage. Heachache rack, brush guard, 100w driving lights. Goerend triple disc and VB.
Ops is offline   Reply With Quote
Old 11-08-2009, 03:40 AM   #67 (permalink)
I swear its like talking to a dozen brick walls.
Old 11-09-2009, 01:12 AM   #68 (permalink)
cLaYtoNs CuMMin's Avatar
Using no clutch is meant for big semi trucks with tranny's as big as a house! But hey, cant find em, grind em.
2002 5.9 2500 QC 4x4 Auto, all stock
cLaYtoNs CuMMin is offline   Reply With Quote
Old 11-09-2009, 08:43 PM   #69 (permalink)
lbdodge24v's Avatar
Good info here, and opinions. Since everything in mine is new, and it hurt the pocket when it was all paid, I use the clutch for now, can't see where i can go wrong doing that. But somewhere back a few pages, someone said something about a dual disc clutch when floating the gears. Would a dual disc make any difference in diong this or not?
On to the new problems with it though. LOL
02 Dodge Ram CTD, 6 spd. with some power adder parts.
The Toy: 93 Jeep Wrangler, rolling on 44 in Boggers, powered by a Cummins with some smoke !!
lbdodge24v is offline   Reply With Quote
Old 11-09-2009, 08:46 PM   #70 (permalink)
shifting clutchless is the same with a dual disk, and more of a reason to since the tension on that clutch pedal is considerably more
Old 11-09-2009, 10:23 PM   #71 (permalink)
lbdodge24v's Avatar
Just was asking, mine is actually about the same with the dual disk as it was, but it has always had a stiff pedal, now if the rims would stop cracking.
Old 11-10-2009, 01:04 AM   #72 (permalink)
BlackedOut02's Avatar
no clutch = no syncros found that out the hard way
'02 | 2WD | 2500 | NV4500
"Diesels dont run away. Diesels over speed, mechanics run away"
BlackedOut02 is offline   Reply With Quote
