| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
| View Poll Results: How do you shift? | |||
| Use Clutch for every shift |
136 | 73.91% |
| No clutch for shifting |
48 | 26.09% |
| Voters: 184. You may not vote on this poll | |||
#37 (permalink) | |
If you can't fix it with a big hammer, you got an electrical problem! 01 QC SB HO 6 spd 4x4 3.55's, Airdog 100 , 265/75/R16 GY Silent Armors, Silencer ring gone, de-badged, BHAF with black Outerwares, Lukes Linked front end
#38 (permalink) |
you can easily clutchless shift these trucks, just like a semi, HOWEVER ..... its rough on the syncros, a friend of mine had worn out sycros on his, i think from power shifting it, so he decided to just not use the clutch, if your syncros are shot, why worry about ruining them otherwise the syncros are pretty reliable
2002 Dodge Ram 2500 HO, 6 Speed, 4x4 with a 4 inch lift on 37/12.50R16.5 Military issue Humvee Tires , Silencer Ring MIA, Engine bone stock .... For now To Come: Traction bars, New VP44, 150 HP injectors, BD super B special turbo, and some electronics
#39 (permalink) |
people, theres a reason these transmissions have synchros......this aint a fuller 10 speed with non synchro gears meant for jammin.dont come grippin when you start grinding in every gear after 20k or you break a clutch disk in half or snap a input shaft
2001 Ram 2500HO, NV5600, Just an ol ranch truck,362rwhp,811ft/lbs 10/24/09 ![]() Just Ledoux it-RIP Chris Ledoux |
#40 (permalink) |
i drive my PETERBILT with no clutch.
2000 cummins 2500 auto. 2WD, BHAF. silencer ring MIA, juice with attitude w/ hot unlock. 4'' straight pipe, fass 150 high performance fuel pump. i need more money. |
#41 (permalink) |
i always use the clutch...dont even consider it!
05 3500 6 spd Blacked out, 750 hp South Bend dual disk competition clutch, HOT Edge Juice w/attitude, Airdog 150, AFE stage 2 intake, 4" turbo back to 8" single black stack, KORE leveling kit, stock wheels on 35" Mud Grapplers |
#42 (permalink) |
we could go into a long, detailed discussion on why not to float shift your pickup.... but the bottom line is: DONT DO IT! its been discussed on here before, synchro's and helical cut gears are just a couple reasons NOT to float shift your transmission
01.5 3500 6speed 4WD club cab Laramie SLT. BD superB, airdog150GPH, quadzilla adrenaline/pulse, 4" TBE, 5" stacks, 3 piece manifold, ARP head studs, BHAF, PSC steering brace, Valair HD hydraulics, ISSPRO gauges |
#43 (permalink) |
I dont use my clutch to shift, until i get concrete proof that it hurts something then i will continue to do so. 25k and still counting, not to mention i just had the trsnny pulled at a shop and the synchros and everything still look new. You just have to know how to do it right
02 6spd dually, Fass, ARP, Hamilton,ATS, HTT, Haisley, ADR, Snow, Southbend. |
#44 (permalink) |
i never use the clutch....i up shift and down shift with out no problems as long as you match rpms it goes right in and out..but i prob do it out of habitt from driving the dump trucks all the time
#45 (permalink) |
01 Cummins
![]() Join Date: Jul 2009
Hey, I guess I've never really tried to downshift with out the clutch, it always seems to be a little harder, but that might just be me??!! ![]() Later, Winslow
Black 2001 Dodge Ram 2500 Shortbed, Ext. Cab 4x4, 5.9 24 valve, TCW-3, 2-cycle oil in every tank, 54 Block!! , NV 4500, 3.55 gears, Anti-spin, B&W Turnover Gooseneck Hitch, Autometer Ultra-Light Boost, EGT, and Fuel pressure gauges, Valair 13" Kevlar/Ceramic 3400 lb Single Disc Clutch, Valair Upgraded Hydraulics, Edge Comp Programer, 3" Straight pipe for now, BHAF with custom 7075 T-6 Heat Shield, AFE Torque Tube, Air Dog II DF-165 with custom cover!!
#46 (permalink) |
easy to down shift clutchless....just slip er outta gear, rev it up a lil bit...then just slide the shifter into gear.....
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link 02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up... |
#47 (permalink) | |
01 Cummins
Thanks! I'll try it tomorrow!! I'll probably f*** something up, but that's the way I roll!! ![]() ![]() Later, Winslow
#48 (permalink) |
SCRRRP
![]() Join Date: Dec 2007
can someone explain to me the purpose of not useing the clutch??? I believe its there for a reason?!?! Not trying to stir anything up but what in the world is the point?
01 Red Sport X-cab SB 4.10's 6spd 4x4, Drag Comp, 62/71/14, 125hp stix, luk clutch, Raptor 150,boost & EGT gauges, intake, 4" exhaust, new brakes and front end
