| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
Cost to rebuild a VP44
What does everyone think? Seems that the rebuild kits (seals at least) are around $50. The chip set and steel insert? How much could this be? And then, the technician's time and cost of the calibration stand use. What does everyone think it truly costs to rebuild a VP44 to Bosch standards with a 1-year warranty?
1999 dually 4x4, Edge Level 5, DD 3 injectors, Full ATS Trans and Co-Pilot, FASS150, Custom TDR Cam, ATS 3-piece Header, Custom Down Pipe, Banks High Flow Intake, Propane, 4:10 Gearing, AmSoil front to back, 5-inch exhaust, 1500 watts (I can't hear the engine)
#2 (permalink) |
honestly just buy a new one.....u will proably end up just spending more money with the rebuilt kits and labor...then it will break and you will want a new one..
98.5 Blue 2500, 5speed, edge juice w/ attitude, BHAF,FASS150GPH,5 inch str8 pipe,halo projectors, tow mirrors, smoke switch, silencer ring MIA, 2rockford fosgate p2s in a custom fiberglass box, black interior, valair 12 1/4 500hp clutch.
#4 (permalink) |
yup....it would be cheaper to just buy a remanufactured one....
CJ's truck....got a problem w/ your VP powered truck?? click===>>this link 02 5 speed/stock ish... w/ a Scan Gauge II monitorin stuff... TCW3 Two Stroke lubin er up... |
#5 (permalink) |
guys have been trying to get away with this for years...unfortunately theres a reason why we all buy a new one instead
01 Dodge 2500 CTD regular cab long bed automatic,Hell Bent Steel 2" leveling kit, 33" BFG Mud Terrains, Raptor 150, isspro gauges, ATS double deep tranny pan |
#6 (permalink) |
GA VP...so close to 500hp
![]() Join Date: Oct 2007
Where are you going to find someone with the calibration bench that would only piecemeal a VP44 back together?
1999 2500 4x4 Club Cab Sport. sorta functional ADRENALINE/pulse , BHAF, FBD 150 sticks, 3rd Gen HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost and Drive pressure gauges, fuel pressure gauge, FP light, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
#7 (permalink) |
if you find a way to reliably repair one more power to you. we all would love to know.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100. |
#8 (permalink) |
technically people like you and i cant pull them apart and rebuilt them because when you pull it apart it has to be recalibrated, and if you happen to have a $200K calibration bench in your garage please fill me in ![]() otherwise the solution is to buy a new one, there $1200 +/-, avoid the black colored ones, there cheaply made, and make sure you get an aftermarket lift pump too (FASS, raptor, Air Dog, Etc) they usually run $4-600 or so, as for the warranty most places the pump comes with a 1 year, theres a place here in fresno that is a certified Bosch facility that gives a 3 year warrany with the purchase of the pump
2002 Dodge Ram 2500 HO, 6 Speed, 4x4 with a 4 inch lift on 37/12.50R16.5 Military issue Humvee Tires , Silencer Ring MIA, Engine bone stock .... For now To Come: Traction bars, New VP44, 150 HP injectors, BD super B special turbo, and some electronics
#9 (permalink) |
Diesel Auto Power
![]() Join Date: Feb 2006
4 out of 5 times the VP44 failure is electronic. the dealer cost on the electronics box is about $350, + you have to calibrate it on a $100,000 test bench (add another $200) + install and seals and its only part rebuilt and you are at about $700 + your labor. Better to just get a new remanufacured pump. Check out my signature.
www.DieselAutoPower.com Call Jacob at 951-377-4844 for best pricing SUPER DEALS on Injection pumps, Turbos, Injectors & Programmers SUMMER SPECIAL--8% off after REBATE(up to $200 off per transaction.) When you buy from me on Ebay and pay with paypal you will receive an 8% rebate from Ebay in 60 days. Call me for rebate coupon code or questions. Example: Buy VP44 for $1000- 8% Rebate of $80= $920 after rebate |
#10 (permalink) |
It wouldn't be so bad if they did have the stupid calibration test bench thats 120k. I know people that could get the parts... cheap. But the problem is that you have to get it calibrated.
02 4x4 Auto, Stage 1 Jammers, BHAF, New VP44 pump, Fuel pressure gauge, Superchips Flashpaq & Straight Pipe |
#11 (permalink) |
i have a ton of research on rebuilding and you either come out the same as a reman or a little higher but then you also have the down time of pulling rebuilding and then shipping back. so why wouldnt you just purchase a reman and then you down time is cut in half and at the same price.
2001/NV5600/TWINS/200hp STICKS/ARP STUDS/110lb SPRINGS/QUAD ADRENALINE/RAPTOR 150/ISSPRO GAUGES/DEVILS OWN METH INJECTION/5in EXHAUST/SBC3600 DD/SBC HYDROS/IN SEARCH OF 600HP AND BUILT WITH DIESEL AUTO POWER PRODUCTS |
#12 (permalink) |
The problem in part is diesel Injection pumps are to Bosch as diamonds are to DeBeers. They have the parts captive and no one has ability to secure all components, and bench tools and knowledge. Bosh has very strenous requirment to be approved rebuilders. As others say, just buy what you need with a warranty and be happy.
2000 Big Blue Beast 3500 SLT 2WD heavy hauling auto, stage 1 injectors, 232K miles and still growing. Toys from .049 airplane to 1248 CI D8H dozer. Wanna play! |
