| 98.5-02 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect..NO ADVERTISING . |
water in fuel ....
yeah so i washed the motor down to clean up some of the grease, and i turn the key on and the water in fuel light stayed on ... so my question is what the hell do i have todo now ... never had this problem
00' auto 4x4 (all the mods are the only mods, everything else is stock with 223000 miles....... FASS 150, EDGE juice, MBRP 5" stack, AEM intake, FBD 150 sticks, BD Super B Special ...396hp/689tq at 32psi |
#2 (permalink) |
01 Cummins
![]() Join Date: Jul 2009
Hey, There is a drain on the fuel filter housing. It has a hose on it, open the valve and let it drain! I don't know how water would have got in there, but that's where the sender is!! Does it still have the stock fuel filter housing on it??? Or is the sender just hanging in there??? Later, Winslow
Black 2001 Dodge Ram 2500 Shortbed, Ext. Cab 4x4, 5.9 24 valve, TCW-3, 2-cycle oil in every tank, 54 Block!! , NV 4500, 3.55 gears, Anti-spin, B&W Turnover Gooseneck Hitch, Autometer Ultra-Light Boost, EGT, and Fuel pressure gauges, Valair 13" Kevlar/Ceramic 3400 lb Single Disc Clutch, Valair Upgraded Hydraulics, Edge Comp Programer, 3" Straight pipe for now, BHAF with custom 7075 T-6 Heat Shield, AFE Torque Tube, Air Dog II DF-165 with custom cover!!
#3 (permalink) |
Sounds to me like the culprit was because you washed under the hood. The connectors for the water in fuel sending unit may be loose causing it to read water in the fuel. Anyways, to be on the safe side, drain the filter like stated above, and then let her rip
98.5 3500 2WD dually 4:10's lFull Auto Meter lByrds intakel64/71/14 lGHDlARPl150 horse sticks l.093 tubesl Smarty lEdge Comp HOT lStage 2 snow kitlAir Dog lAmsoil lGeorend trans l VP intercooler boots 536/1175 10/17/09 |
#4 (permalink) |
i didnt put the fass on, but i dont see the old houseing just 2 connectors hanging lol ill go drain now
#5 (permalink) | |
01 Cummins
Wipe off the sender (one is water in fuel, other is fuel heater) and I bet you'll be good to go. Put tape over it so it won't happen again!!! Later, Winslow
#6 (permalink) |
AHHHH, if there is a FASS on there with the spin on filters, it probably won't have the stock filter housing. Mine does this with an AIR DOG unit on it. Everytime I drive through the rain, the light will come on. More so, when I pressure wash it. No problem there, just run it.
#7 (permalink) | |
01 Cummins
That's why I electrical taped mine so I won't have that problem!!! I removed the fuel heaters and taped up the plug to prevent a short!!!! Later, Winslow
#8 (permalink) |
yup just had to drain the filter, its all good, thanks guys and ill deff. go tape that sender up,
#9 (permalink) |
get some bishop tape on it before you tape, adds a lil more water proofing.
1999 2500 Laramie 4x4, Longbed, nv4500, goose neck hitch, boost/pyro gauges, raptor 100. |
