Bd Apps Noise Isolator - Dodge Cummins Diesel Forum
post #1 of 36 (permalink) Old 11-03-2009, 09:00 AM Thread Starter
DieselRiot's Avatar
iTrader Score: 5 reviews
Ok so i picked up the bd apps noise isolator yesterday from xdp and the instructions are VERY VAGUE.
All it says basicly is to tap into the apps wire which is orange with blue tracer.
Well the wire starts at the pcm and runs throughout the harness and ends some where else unknown to me.
SO what i am asking is where do i cut that wire?
I know it either starts or ends at the pcm and the wire that bd supplied seems like it has to be put inline and grounded somehwere.
Any help would be great.
THanks guys.
2008. EFI Live By Cummins-Tuner. Copilot. 5" TBE. S&B Intake With Scoop. GDP Mega-Flo With Boost Tube. GDP Pro-Gate. GDP CCV Delete. WCC Silencer Ring Mod. Rail Shim. Fass Ti 150. ARP 425's.
DieselRiot is offline
post #2 of 36 (permalink) Old 11-03-2009, 09:05 AM
VP Moderator
dozer12216's Avatar
You cut it somewhere between the APPS and PCM, where you have good access.
dozer12216 is offline
post #3 of 36 (permalink) Old 11-03-2009, 01:10 PM
Vice President
Dave at BCDiesel.ca's Avatar
I just looked at them and yes they are a little vague. I have sent an email to have the noise isolators manual/single page enhanced.
Thanks for the feedback
Dave at BCDiesel.ca is offline
post #4 of 36 (permalink) Old 11-04-2009, 08:02 AM Thread Starter
DieselRiot's Avatar
Even that is vague.
Becuase one end has a "But connector" and the other is a ring terminal.
In in a sense you are saying to either cut it out of the pcm or out of the apps sensor???
I called bd and one of the tech guys said to not tap filter off the wire but to like find the end. . . idk.
post #5 of 36 (permalink) Old 11-04-2009, 08:04 AM Thread Starter
DieselRiot's Avatar
So where does it get installed?????
post #6 of 36 (permalink) Old 11-04-2009, 12:48 PM
kstinson's Avatar
There are only two connections on it? Typically a dc noise filter/isolator will have 3 connections. One will be the input, one the vehicle ground, and the other the output. The reason for this is the filter is usually nothing more than a capacitor. It removes allows the alternating components of the DC signal to pass to ground while preserving the steady DC signal.
I am guessing that the ring terminal is either ground or the case somehow grounds the circuit.
Take a picture of the unit and maybe we can help.
2000 Black Dodge Ram 3500 Dually 5.9l 24-Valve, NV5600 6-Speed, Edge Juice/Attitude, AirDog 150, Hydroboost to keep the front end lubricated ;-)
kstinson is offline
post #7 of 36 (permalink) Old 11-04-2009, 01:15 PM
Vice President
Yes the ring terminal is ground...
post #8 of 36 (permalink) Old 11-04-2009, 01:18 PM
Vice President
BD Noise Isolator
Here is the manual
post #9 of 36 (permalink) Old 11-04-2009, 06:09 PM Thread Starter
DieselRiot's Avatar
ok so i guess it just taps off the wire and then goes to ground.
Any spot that would be better to place it in?
Closer to the pcm or closers to the apps?
post #10 of 36 (permalink) Old 11-04-2009, 06:30 PM
kstinson's Avatar
Being its to clean up the dirty signal from the APPS I would place it as closely to the PCM as you can get. This will limit the possibility for other noise.
kstinson is offline
post #11 of 36 (permalink) Old 11-04-2009, 07:14 PM Thread Starter
DieselRiot's Avatar
ok good b/c there is a good spot to tap it right after the pcm.
Thanks alot guys
post #12 of 36 (permalink) Old 01-13-2010, 04:10 PM
DavidC's Avatar
Did this help the trans any?
2001.5 Ram 2500 Quadcab Black Sport CTD,Billet Goerend,Edge Juice,5" MBRP,50hp Sticks,HX35/40
2001.5 Ram 2500 Quadcab Black sport 4X4, Built Trany, 5" pipe, Edge Comp,
DavidC is offline
The Following 2 Users Say Thank You to DavidC For This Useful Post:
dwebb16 (08-17-2013), Ifitdntsmkblktakitbac (12-03-2012)
